New Chain Help - Installation
4 replies to this topic
  • jhawker21
Posted May 15, 2007 - 07:23 AM
OK Guys, I need to pick your brains a bit.
I've recently purchsed a new chain and sprockets for my 02 YZ426. I went with a 14/50 setup and a 120 link chain with a master link. I'm still learning new things all the time and I've figured out I need to remove some links in the chain.
I counted the old chain that came off the bike and it has 113 links, with the stock 14/49 setup.
2 questions: 1) How to I remove the necessary links, with a chain breaker, grinder..any ideas? 2) Anyone have this setup and know how many links they have on their chain.
A buddy told me I need to add or subtract links based on how many teeth my sprockets have so I'm wanting to make sure I do this right the 1st time so any help would be greatly appreciated!
Thanks,
Eric:ride: :applause: :applause:
  • Rich_in_Orlando
Posted May 15, 2007 - 09:34 AM
The stock chain length for my '99 WR400 is 114 links with a 14/50 sprocket combo. That would be the appropriate length for your bike, too.
If you have a chain breaker, use that. Otherwise use a grinder/dremel tool.
  • jhawker21
Posted May 15, 2007 - 11:24 AM
Thank for the response! I have a grinder and a vice so I think I'll try to grind 1st and use a punch to push out the pins. I also agree that 114 links is correct.
Thanks again!
  • kskyles
Posted May 15, 2007 - 12:05 PM
you can definitely do that. i use a dremel and a motion pro chain tool.
i'm all for saving some bucks, but the chain tool has been a really nice investment. especially if you have more than one bike in the family.
  • jhawker21
Posted May 16, 2007 - 08:48 AM
Fixed!!!!
Thanks for the help. I was able to grind down the 6th link to end up with 114. I then punched out the pins and was able to get my new chain installed! New sprockets and chain are installed and good to go.
Thanks for the help!
Eric
