01 YZ426 Cluch Problem
5 replies to this topic
  • fbroll
Posted May 14, 2007 - 08:55 PM
Just purchased a 01 YZ426, the cluch pull is very hard. Is this common. Went for a wood ride and my hand sore.
  • SRT426
Posted May 14, 2007 - 11:09 PM
It's not an easy pull but it's not that stiff either. Try adjusting the lever position, you may have it to far from the grip for your hand size and the extra pull is causing the discomfort. Back out the adjuster so it hangs a bit looser and this should help. Also for woods riding gear down to 13/50 and you won't to use the clutch as much and it really pulls hard in tight conditions..
  • markvan
Posted May 15, 2007 - 08:50 AM
I drilled out my clutch lever to move the position that the cable locks into, giving more leverage when the lever is pulled. There is also a longer actuater arm available, (01 or 02? not sure which year is longer than 00). I found that the lever modification made a big differance.....much better than before....
  • Gerry B
Posted May 15, 2007 - 08:57 AM
try lubing your cable
  • frodaddy2921
Posted May 15, 2007 - 04:42 PM
lube your cable and try a 400f clutch arm. its longer than the 01. made mine pull like a 250 two stroke:thumbsup:
  • 642MX
Posted May 15, 2007 - 04:58 PM
Replace the cable. Its probably frayed somewhere causing the hard pull.
  • 5 replies
  • Hot  36 replies
Is the 2016 GYTR Yamaha YZ450F too fast? by Fryboy
  • Hot  241 replies
yz400f throttle bog by yz400fmaniac
  • Hot  28 replies
