1998 XR600R Owner's manual / info needed.
7 replies to this topic
  • reydon
Posted May 14, 2007 - 10:42 AM
Hello everyone and greetings from Cape Town. I just got my XR600 last week, but alas, no owner's manual. I need the information on suspension setup that is aparently covered in the manual. I found that there is only 30PSI in the rear shock and believe it should be more in the 250PSI range? Does anyone possibly have a scan of the owner's manual, or even only of the relevant section. Any assistance greatly appreciated. Reydon
  • jonnyherbs
Posted May 15, 2007 - 02:29 PM
I only have the repair manual- I couldn't find what you are looking for, but maybe this will help you get it set up:
Adjusting preload setting on the rear suspension
Locking nut torque specification 90 N.m - 65 ft-lb
1988 to 1990
Spring length Standard 234 mm - Maximum 229 mm - Minimum 239 mm
After 1990
Spring length Standard 200 mm - Maximum 195 mm - Minimum 205 mm
  • Jon-D
Posted May 15, 2007 - 03:17 PM
250 psi is about what a rear shock N pressure should be at. Some riders run a little lower pressure, some a little higher. I filled my shock (1993) to 250 psi after replacing the fluid it and it works like it should.
  • reydon
Posted May 18, 2007 - 01:51 PM
Thanks for the info, guys. I would still love a copy of the XR600 owner's manual if anyone has it.
  • exaresix
Posted May 19, 2007 - 03:38 PM
It would be much easier to just buy one for $16:
http://www.helminc.c...6HXNKTKU35908K1
  • reydon
Posted May 22, 2007 - 10:42 AM
I have tried to buy this at helminc.com BUT at $125 for postage to SA and another $25 for handling - NO THANKS!!!
Anyone with a scan of the manual, pleeeease! I dont need a 1998 specific, any manual between 1991 and 2000 will do.
Reydon
  • FZ1426
Posted May 22, 2007 - 02:34 PM
One of the guys at OC Honda looked it up for me yesterday. 213 psi.
  • reydon
Posted May 28, 2007 - 02:09 PM
Thanks FZ
Washington
  • Hot  32 replies
  • 7 replies
Honda XR650L 2016
  • 0 reviews
  • Hot  28 replies
Fell Off Trailer by usafxr
  • Hot  43 replies
