torque settings
3 replies to this topic
  • waynecappleman
Posted May 12, 2007 - 06:05 AM
i need settings for the head and barrell ,xl600,desperate!!!!!!!!!!digger2006@tiscali.co.uk.any answer appreciated HELP!!!!!!!:applause:
  • randall205
Posted May 14, 2007 - 02:17 PM
What year is it? I'll look in my manual tonight and see if it has any info. Thanks,
-Jed
  • randall205
Posted May 15, 2007 - 06:44 PM
Here's what my manual says (it's a Clymer manual):
Cylinder head cover bolts:
6mm -- 8-12 Nm or 6-9 ft.lb
8mm -- 1985-87 20-26 Nm or 15-19 ft.lb
8mm -- 1988 on 23 Nm or 17 ft.lb
8mm -- All other models 26-30 Nm or 19-22 ft.lb
Cylinder Head bolts:
XR600R 1985-87 28-32 Nm or 20-23 ft.lb
XR600R 1988-on 36 Nm or 26 ft.lb
All other models 28-32 Nm or 20-23 ft.lb
Cylinder bolts:
47-53 Nm or 34-38 ft.lb
I hope that helps or at least gets you in the ballpark.
Thanks,
-Jed
  • randall205
Posted May 15, 2007 - 06:48 PM
Here's valve clearance info in case you need that:
XR600R & XR600L:
Intake 0.10 mm (0.004 in.)
Exhaust 0.12 mm (0.005 in.)
All other models:
Intake 0.05 mm (0.002 in.)
Exhaust 0.10 mm (0.004 in.)
The manual is supposed to cover years 1979 thru 1997, so if yours isn't in that era the values may not be applicable.
Thanks again,
-Jed
  • 9 replies
  • Hot  60 replies
  • 3 replies
Honda XR650L 2017
  • 0 reviews
Honda XR650L 2016
  • 0 reviews
