Ais...diy....have I Done This Correctly
2 replies to this topic
  • muddyken
Posted May 11, 2007 - 03:01 PM
i got tired of waiting for my AIS removal kit to arrive from my dealer ( ordered nov 06 ) so tried a diy effort by plugging up the ends with loctite and steel bar thAt fitted snug in the PIPES
http://img295.images...image=awrk6.jpg
does this look to be correct
there is no popping on decal and i have removed all the bits and pieces
cheers guys
  • tony1970
Posted May 11, 2007 - 05:58 PM
Order the TT AIS kit from the TT store. May cost you a little for shipping, but a very clean install. Your mod looks like it will work though.
  • dl19
Posted May 11, 2007 - 08:53 PM
I just the cut the rubber air hose above the clip, filled with silicone, same on air box, re-routed the crank breather to the upper inlet, cut the metal air tube just off from the header, bent it flat, brazed it shut. Looks super clean and works perfectly for less then $1.00.
