07 WR 450 suspension spring sizes
4 replies to this topic
  • SurvivorMan
Posted May 11, 2007 - 02:05 PM
I did a search and could find no info on spring rates, so lets get the rider weights to spring size figured out. I believe that riding ability and speed lies in the valving so your style/speed of riding or racing does not matter.
The manual only lists one size larger for the rear shock spring and then one size larger for fork springs with optional shims.?
I am 230 lbs(all weights should be given with out gear on), what is the correct shock and fork spring sizes for my weight? i ran 48's in my forks on my 06 YZ 450, so i think that should work unless the forks are not compatible.
  • muddyken
Posted May 11, 2007 - 02:39 PM
i would call up a suspension specialist/spring supplier and they can work out spring rates for you,but i am certain you should have a revalve done at the same time, as springs on there own will only offer a limited improvement just my 2 cents:prof:
  • FreeRideSouth
Posted May 11, 2007 - 05:46 PM
Spring rate chart http://www.racetech..../searchdirt.asp
I was searching for the same info and was pointed to RaceTech by Apache Yamaha in AZ.
  • xrmarty
Posted May 11, 2007 - 09:55 PM
I'm exactly your weight. Check out this thread:
http://www.thumperta...ad.php?t=504329
  • SurvivorMan
Posted May 12, 2007 - 06:41 PM
thanks, that really helps.
