Flywheel weight installation
It really just depends, I have use bolted on plates before and you really need a drill press to do it properly... if it's an entire flywheel the whole process shouldn't take more than 30 minutes including draining the oil.
J
True; if you run the bike you don't need to drain, if it's been sitting for a while there will probably be a little oil in there, of course you could always lay the bike on it's side as well (turn off your fuel.)
J
Just finished this on my 06. Pretty darn simple. Had to buy a special flywheel puller, about $30. I was changing my oil and filter anyway so I drained it, changed out the flywheel, then filled with oil. Took about 15 minutes.
can you guys tell me how the motor felt after adding more flyweel weight?
I don't have one, but have heard the power is alot smoother and they are less likely to stall in slow situations.
The motor feels awesome!!! I put the GYTR off road flywheel in my 07 and the difference is night and day. The bike will lug like a WR and has so much more useable power. It has been the best mod I have done to the bike by far.
