Yamaha GYTR™ Two Stage Foam Air Filter
6 replies to this topic
  • canyonclimb
Posted May 09, 2007 - 05:10 PM
This is my first time using a two stage filter. I am about to clean this filter for the first time and I was curious if those of you that have used a two stage filter, apply filter oil to only the outer layer or to both layers?
  • btc20mx
Posted May 09, 2007 - 06:39 PM
both layers.
Posted May 09, 2007 - 07:40 PM
Always thoroughly oil any foam element 100% through the entire mass of the foam media. Foam filters are worthless without oil.
  • Florida_426
Posted May 10, 2007 - 06:01 PM
What both men have posted and be sure you squeeze the excess oil out and, allow the filter oil to set up before you start the bike. Also, do not wring the filter when cleaning or getting the excess oil out. Simply squeeze the foam well, wringing it will stretch the foam material and possibly tear it.
Bill
  • BergArabia
Posted May 10, 2007 - 06:06 PM
Bill
good point on the squeezing and not wringing. easy mistake to make :applause:
  • CaptainKnobby
Posted May 10, 2007 - 06:25 PM
And also I might add!........ :applause: I found out that after you have oiled your filter up adn thought you squeezed out all the excess adn laid it up to dry,be sure to take a look at the rim of the filter where the foam actually stops and the seal starts. I have found when the filter is put up after you have oiled it the time it has spent sitting in the same spot the oil drains down to the seal and you may have to squeeze it one more time. Just thought I might add that so every one can check so you dont gum up your air breather boot:thumbsup:
  • 642MX
Posted May 10, 2007 - 06:49 PM
Did I not answer your question once already today? :applause:
http://www.thumperta...ad.php?t=505588
