2004 YZF450 tank on 2004 WR450?
6 replies to this topic
  • BrianM500EXC
Posted May 09, 2007 - 04:04 AM
I have a desert tank on a 2004 WR450 and need a stock tank for riding track. Will a stock 2004 YZF450 tank fit a WR450? If so, what radiator shrouds will fit?
Thanks.
  • BrianM500EXC
Posted May 12, 2007 - 09:22 AM
Anyone?
  • ncmountainman
Posted May 12, 2007 - 06:45 PM
the tank will fit but will require 04 yz seat and shrouds:thumbsup:
  • BrianM500EXC
Posted May 12, 2007 - 08:00 PM
Thanks for the info.
  • PBDBLUE
Posted May 13, 2007 - 05:12 AM
Just one additional note. You will have to modify the YZ seat to fit by carving out some of the plastic and the hook from the seat pan. The YZ uses the traditional hook that goes under the frame at the front of the seat and the WR uses the two hooks on the sides in the middle. When you are through the seat will be held on by the button on the tank and the two bolts at the rear. I've been running this setup for several years and have yet to have the seat come loose. My guess is an '05/'06 WR seat will fit w/o mod since the stock tank is very similar in shape to the YZ.
  • BrianM500EXC
Posted May 13, 2007 - 01:09 PM
Thanks for the info, PBD. I guess I found a WR450 stock tank, so I'm going with that, but thanks for your help.
  • TeamScream
Posted May 13, 2007 - 10:16 PM
Its a good mod, makes the bike look a lot sweeter
