XR650L questions
5 replies to this topic
  • Rico1
Posted May 08, 2007 - 09:46 AM
Hello everyone,
I just purchased a 2002 XR650L and have a couple of questions I hope someone on here can answer.
1. Will the cam from a 2006 XR650R fit it and if so is it a hotter cam, I would think that it is.
2. Is there anything I should know about removing the "smog pump" other than to get the plates. Will jetting be affected? Will I see an increase in performance?
The bike has stage 2 jetting, a Uni filter, air box opened up and an FMF Power Core 4 slip on.
Rick
  • TDC71
Posted May 08, 2007 - 10:02 AM
Congrats on the bike. Lots of experience here on tap. The R and L have totally different engines so the cam swap is not feasible. Cams can be swapped between the xr600 and 650l though. good luck and have fun.
Todd:thumbsup:
  • martinfan30
Posted May 08, 2007 - 12:43 PM
smog removal is simple, but make sure you do the hoses correctly according to the intructions.:applause:
  • XR650L_Dave
Posted May 08, 2007 - 02:00 PM
There is no performance or jetting change when eliminating the smog carp.
Dave
  • Rico1
Posted May 08, 2007 - 03:24 PM
Thanks everyone for the input. Martinfan, what instructions are you referring to?
  • TDC71
Posted May 08, 2007 - 03:33 PM
Type in "smog removal"under the search engine and loads of info will pop up.
Todd
  • Hot  186 replies
  • 9 replies
  • 3 replies
  • 22 replies
  • 17 replies
