Pinging/knocking?
6 replies to this topic
  • BrianM500EXC
Posted May 06, 2007 - 06:09 PM
Just rode my new for me '04 WR450. Noticed if I give it a lot of throttle at low revs, it sounded like it was pinging/knocking. Is this common? Advice?
Thanks!
  • Gadsen
Posted May 06, 2007 - 06:41 PM
Thanks!
No, it needs higher octane fuel. That engine has a 12.5:1 compression ratio and requires 95 octane. But I run 92 pump gas and never heard it ping. Make sure you are not hearing chain slap.
  • BrianM500EXC
Posted May 06, 2007 - 07:52 PM
Thanks - I'll try some octane boost and see if that helps - only 92 octane in CA.
  • WR450RICKO
Posted May 07, 2007 - 10:30 AM
91/92 octane is fine
  • gregwr450f
Posted May 07, 2007 - 03:04 PM
I use an octane booster in mine, if I don't it sounds like it's going to fall apart.
  • MountainMax
Posted May 07, 2007 - 04:00 PM
you may be hearing your chain slapping also, there is a fix for this by putting silicone under your chain guard on the swingarm
  • SJMC_DON
Posted May 07, 2007 - 07:15 PM
I bought my 07' brought it home and did not even ride it till I did the free mods... I got em' done and went for a ride around the neighborhood and experienced some horrendous pinging and knocking
It was the gas :applause: :applause: :p
Yes chain slap to the untrained ear could sound like engine knock too....
