Just got done modding my 06'wr450
5 replies to this topic
  • thrashmetal
Posted May 05, 2007 - 11:34 AM
I would like to extend a gracious thank you to this site and everyone who contributed info on all the mods:thumbsup:, I didn't have to post once for questions to complete the mods due to all the great info here. I can really tell a difference after the mods, the bike just has so much more balls. I was riding on 12 acres of field and didn't even get past 3rd gear before having to slow down or risk going into a ditch:ride:. All I have left is doing an exhaust mod (Promoto billet on backorder through TT atm). I jetted the carb with a #170 main jet and the blue needle in the 3rd from top clip and installed a zip ty fule mix screw, everything else I left stock. I ride in Washington state anywhere from sea level to 4000'. On a side note if there are any other WR owners or riders in WA, hit me up to go riding, I'm looking for other people to ride with. Also since I'm 6'2" and weigh around 235lbs what would anyone recommend for a suspension setup, what would I need to get?
\m/
Erik
  • notyme2loose
Posted May 05, 2007 - 06:33 PM
I just got the same bike a little over a week ago a left over new. I am 6' 1" and 235 lbs and have ordered new springs front .48kg(stock .46kg) and rear 5.8kg(stock 5.3kg) may dealer is also a RaceTech center which will be installing. I going with this first with no revalve. I ride mostly single track.
Today was my first real ride and enduro loop on a friends property. I like the bike a lot. Its much easier to ride than my XR600 in the tight stuff and the power is good.
  • xr250ryder
Posted May 06, 2007 - 08:18 AM
Where are you at in Washington, and congrats on your purchase. Im still waiting on the Yami shop to get my AIS Removal Kit in :applause:
  • BrianM500EXC
Posted May 06, 2007 - 05:53 PM
\m/
Erik
Question: Is the blue needle preferred over the red? I ride 500-2000' 60-95 degrees in the desert.
Thanks!
  • xrmarty
Posted May 06, 2007 - 10:37 PM
5'11" here at 230lbs. I ended up with same springs. Huge difference on trails!
  • thrashmetal
Posted May 09, 2007 - 07:31 PM
Thanks!
I'm not sure which needle would be better for your situation. There's some good threads on here discussing which needle to use. I contacted JD jetting for further info since it's located here in Washington state. Good luck!
