Showa suspension harsh
20 replies to this topic
  • KtmKramer
Posted May 04, 2007 - 08:25 AM
Hi guys
2006 RM250. Fork shims are stock w/ RaceTech G2R Gold Valves (previous owner had them put in. Stock valves were lost.), w/ 5W oil. Shock shims are stock w/ G2R valve as well. Below are the stock shim settings from the factory, same that are in the bike now.
I ride MX (sand and hardpack) w/ this bike. Lake Elsinore, Cahuilla, etc. No major jumps. Tables, small doubles, but usually lots of hack and braking bumps. I weigh 170 w/out gear. Consider myself a novice MX rider moving toward intermediate. The braking and accel bumps KILL my wrists. Major spike in the mid. G-outs are ok. I've gone in and out on comp and reb, to no avail.
FORKS
47mm, Showa Twin Chamber forks, .44 kg stock, 350 cc, range adj 321/415
(15) .10x30
(2) .10x29
.10x28
.10x27
.10x26
.10x25
.10x24
.10x23
.10x22
.10x21
.15x20
Stock Bleed stack
16.3
10.2
12.1
14.1
15.1
16.1
16.1
SHOCK – 18mm shaft, 5.3 spring, 100 rider sag
.30x21
.30x22
.25x24
.25x26
.25x28
.25x30
.25x32
.25x34
.25x36
.25x38
.25x40
.20x42
.10x30
.15x38
(9).20x44
Piston
(3).20x40
.10x22
(5).30x40
.20x40
.10x32
.30x40
.30x38
.30x36
.30x34
.30x32
.30x30
.30x29
.30x28
.30x27
.30x26
.30x25
Spacers
Nut
I'd like a plush suspension for the hack/square edge bumps, w/ no real need for major bottoming resistance since I don't do big jumps. Any ideas are appreciated.
Thank you!
Gentry
  • KTM-Lew
Posted May 04, 2007 - 10:51 AM
I would call some of the local susp shops that use RateTech products and see if they will selll you the stock pistons for both ends. They should have a bucket full of them...
Or even call Pro-Action or MX-Tech? Without Racetech's help you are going to have a tough go of it...
  • theDogger
Posted May 04, 2007 - 11:10 AM
Here this might help found it on the internet with a little searching...but I would still try and get the OEM valves back in.
theDogger
  • KTM-Lew
Posted May 04, 2007 - 11:40 AM
Nice find Dogger! :applause:
  • mxracer206
Posted May 04, 2007 - 05:23 PM
Dang, that thing looks scary. A little over-kill in my opinion.
  • poynedexter
Posted May 05, 2007 - 11:48 AM
ktmkramer, i'm about your weight etc and with the stock setup i find the shock the plushest i've ever had, but the fork just a little harsh. i'd love to hear the doggers view on how to plush up the fork without making it too soft on bigger landings. :applause:
  • -SuperMoto-
Posted May 06, 2007 - 04:11 PM
You didnt find that with searching did you dogger,
  • 06thumpy
Posted May 06, 2007 - 07:43 PM
take 4 of the .10-30 shims and put on the base washer. i.e. from top of stack to bottom. cant help u with the shock.
  • KtmKramer
Posted May 08, 2007 - 01:40 PM
Thanks, guys. Dogger, you fricking rock! I'll run over to Pro-tec and see if they have some OEM pistons.
  • KtmKramer
Posted May 08, 2007 - 02:14 PM
Anybody: What level should I start at on the LSC and HSC on the chart? They have 20 levels for Pete's sake!! cL10 and cH10 then salt to taste?
  • theDogger
Posted May 08, 2007 - 02:20 PM
That is going to be pretty stiff. I would start in the middle somewhere. Try Brian Wilson on TT he setup up his own RT Valves seemed to know quite a bit about them.
This sheet that I posted came from SuperMoto and his setting that were suggested by RT are in RED! He said that he is an A Class MX rider.
cR10.22
cL6
cG20
cH4
He seemed to like it, had to mess with the oil level a little though....
theDogger
  • KTM-Lew
Posted May 08, 2007 - 06:12 PM
cR10.22
cL6
cG20
cH4
theDogger
For your weight and speed I would back down a bit to cL5 & cH2.
  • KtmKramer
Posted May 08, 2007 - 06:37 PM
Thanks, Lew! I'll give her a go.
  • Dangeroo0
Posted May 09, 2007 - 02:17 AM
I would stick to single stage and use CH3 but replace the top shim with (3).10x30 oil level at 370cc.
There are other things that need to be done to remove the spike from these forks than the passive valving however.
  • KTM-Lew
Posted May 09, 2007 - 04:06 AM
Is that with the G2-R piston?
  • -SuperMoto-
Posted May 09, 2007 - 06:19 AM
with the G2's in they felt a little better,but I realised they said I needed .47 springs where as i'm running .48's,I have changed back to stock .46's and waiting to see how they ride.
  • frezno
Posted May 09, 2007 - 07:08 AM
put in a .46 on one leg and you'll end up with a .47 total
  • KtmKramer
Posted May 11, 2007 - 06:34 AM
Such as? Any help is appreciated in trying to get these forks dialed in.
Thanks
  • MRW
Posted May 13, 2007 - 08:36 PM
I KNOW "Roo" has The Killer "MV" for these forks!!! Come on Roo, let`s see IT!!:applause:
Oh and yes Roo, I know who Ben Townley(spl) is now:applause:
  • Dangeroo0
Posted May 14, 2007 - 04:57 AM
My midvalve is set-up for off road. It would probably work better for you to open the float a little. More gains were made when I modified the compression bypass piston. I'm not on my computer with all my specs, but if you send me an email greg at proride.co.nz I will send you some specs later that I have used to get a great feeling fork for off road, sand, tree roots and MX.
