newbie carb question
2 replies to this topic
  • pianoexcellence
Posted May 04, 2007 - 07:22 AM
the air\fuel screw thing....
now that I've removed the tab, I need to know how to manipluate this thing...
does it controll the movement of fuel or the movement of air?
does turning it out make it richer or leaner?:applause:
thanks in advance for your non-stupid answers to this stupid question:bonk:
  • XR650L_Dave
Posted May 04, 2007 - 08:05 AM
Assuming XR650L CV carb, its a fuel screw, and in is leaner, out is richer.
If you have the correct size pilot jet, the adjustment should be 2-3 turns out from lightly seated (closed).
More than that, you need a bigger pilot.
Dave
  • DiabloCaballo
Posted May 05, 2007 - 10:55 AM
Turn the screw in until the idle changes, then count your turns out until the idle changes again. Go half way. You should be near 2 to 2 1/2 turns out from were the screw lightly seats or your jetting is likely wrong.:applause:
