hour meter?
20 replies to this topic
  • hi everybody
Posted May 03, 2007 - 09:29 PM
hey everybody..
so today I picked up a brand new 07 450(yaaaay!) and also picked up a Hardline hour/tach meter.....only to have the mechanic there tell me that it wont work. he said because the coil is built into the cap, that those kind of meters wont work....but after asking a friend who has the (im pretty sure) same exact model meter..AND same bike....says it will. and I have also seen tons of thumpertalk guys with it on there YZ450s...soo.....will this hour meter not work? or am I just being told false information? thanks!
  • cowboyona426
Posted May 03, 2007 - 09:31 PM
TT has this handy little feature called search... make it your friend :applause: Yes the meter will work, you just wrap the lead wire around the cap of the coil. I have a pic of my install of a SenDec on the coil, but yours should install the same. I'll try to find the pic.
  • cowboyona426
Posted May 03, 2007 - 09:34 PM
Here you go- clicky
  • hi everybody
Posted May 03, 2007 - 09:37 PM
alright...thanks a load.
and my bad on the search...:applause:
  • cowboyona426
Posted May 03, 2007 - 09:45 PM
We'll forgive you, but just this once.
  • kyle450rider
Posted May 04, 2007 - 08:41 AM
another quick tip on your hourmeter.Use velcro with the sticky back on it to mount it.That way if you ever purchase a new bike you can take it with you and not have 2 holes in the frame.
  • Kyle Prior
Posted May 04, 2007 - 02:14 PM
I made my holes bigger, and zip-tied it to the frame :applause:
  • Florida_426
Posted May 06, 2007 - 12:10 PM
Don't see too many of them but I sprung for the Dubach Research mount that goes underneath the nut on top of the top clamp. ice and sanitary, better looking than the 2 sided tape I used for so long.
Bill
  • hi everybody
Posted May 06, 2007 - 06:54 PM
I just used the two sided tape that came with it..and put it up by the frame by the steering head...so far so good!
  • cablemonkey334
Posted May 06, 2007 - 07:02 PM
i mounted mine under the pro-taper bar pad an cut out the pad and flushed mounted it. then cut out around the lcd display looks very trick.
  • CaptainKnobby
Posted May 06, 2007 - 07:06 PM
Look how mine is mounted...... You can see it on pics of captainknobbys yz450f on the post.
  • cablemonkey334
Posted May 06, 2007 - 08:06 PM
not bad but mine is sano i ll post a pic in the morning.
  • Yamahafan
Posted May 07, 2007 - 05:48 AM
Bill
I saw somebody use a similar approach to the Dr D, but they attached the bracket to the top mount on the gas tank. This looked more streamlined and out of the way in case of a crash.
  • cablemonkey334
Posted May 07, 2007 - 10:04 AM
this is a pic of my hour meter under the bar pad
Posted Image :applause:
  • greentyler
Posted May 13, 2007 - 08:43 PM
WOW! I'm picking up a new bike this week, and this is exactly how i'm mounting my hour meter!!!
Thanks for the idea!
  • fetz518
Posted May 14, 2007 - 05:48 AM
Am I the only person that used two little zipties to mount it to the wires running down the right side of the frame? It works great and it's removable.
  • neevothespaniel
Posted May 14, 2007 - 01:41 PM
Looks trick. But what happens if you headbutt the bar pad in a crash. Wouldn't you smash the hour meter a bit :applause:
  • cablemonkey334
Posted May 14, 2007 - 07:01 PM
no worse than being on the frame an gettin t -boned , theres a chance it could be hit anywhere, its clean an easy.
  • tnl
Posted May 14, 2007 - 08:43 PM
Me too!:applause:
  • Kyle Prior
Posted May 15, 2007 - 06:49 PM
I mounted mine in that little open area in the frame, and i really like it there. Its nice and protected... Sorry for the crappy pic.
  • 0 replies
  • Hot  38 replies
