Distinct hot oil smell from my 07
16 replies to this topic
  • 700MX
Posted May 03, 2007 - 07:47 PM
Any ideas on what it could be????? It has smelt like oil since new........ and it just gets me worried. my freinds can smell the oil when I ride by them
THANKS
700
Posted May 03, 2007 - 09:42 PM
Are you a Rotella user?
  • SXP
Posted May 04, 2007 - 06:59 AM
I am - on my 99s and 07. No oily smell from the 07 or one of the 99s. The other 99, however, is getting tired and spits excessively through the vent hose, and I get a distinct hot oil smell from the bike when I shut it down. But I believe it would do it with any oil.
  • never59
Posted May 04, 2007 - 07:59 AM
As usual gray racer is dead on with the stinky rotella oil. I use it and it stinks, no way around it. Stunk in my 02, 04 and now my 07. Great oil but literally stinks. I will just leave it at that. No oil debates please???:applause: :applause:
  • kyle450rider
Posted May 04, 2007 - 08:38 AM
just get some of those pine air fresheners and hang them from your bars.That way you will always have that fresh pine scent wherever you go.LOL
  • BergArabia
Posted May 04, 2007 - 10:11 AM
Interesting and very useful information to have.. :p
Posted May 04, 2007 - 01:35 PM
... literally stinks. I will just leave it at that.
That's what they tell me, alright.
  • 700MX
Posted May 05, 2007 - 09:06 AM
I use yamalube, and change it every other ride. But yea, every time I pull in the pits, my bike stinks it up on the stand........I realise it should a little, but I get a small puddle out of the tube after every moto. Is there a seal that could be bad in the head spitting xtra oil out the tube????
Posted May 05, 2007 - 09:38 AM
No, not really. Over filling, overheating, clutch heat (like with a Rekluse), or excessive blow by from the compression rings could be the cause. Hard to say.
  • 700MX
Posted May 05, 2007 - 11:20 AM
Yea, I am pretty sure its not my rings......
Maybe I am overfilling it. when you check your oil hot, how long do you have before your upper oil drains down and gives you a inaccurate measure ment?
Do you literally check it seconds after you shut it off?? Last time i did that oil oozzed out of the dip stick hole. I am draining both sides, and putting in what the manual states.....maybe all the oil does not release out??????
Also, nothing seams to come out of the level check bolt.........do you check that hot or cold?????
THANKS
700
Posted May 05, 2007 - 11:53 AM
You need to wait at least 30-60 seconds or oil will bubble up from the return circuit. If everything is working as it should, you'd have at least an hour before drain back affects the reading you get.
The overfill bolt should be checked hot, at the same time as you would check the dip stick.
  • 700MX
Posted May 05, 2007 - 02:24 PM
Thanks.......
Have you noticed the factory Yamis dont have the black tube, wonder why.....weight???
  • black_n_blue_thumper
Posted May 05, 2007 - 04:53 PM
Dude at least you made me laugh. I know it doesnt help to find answers to someones question, but a little humor every now and then does me good. :applause:
Posted May 05, 2007 - 05:11 PM
What black tube? The breather? Has to have one somewhere.
  • bigred455
Posted May 05, 2007 - 06:11 PM
You need to check your oil as soon it is shut down,not after a hard run.Just let it idle a couple minutes then shut it down and check. The longer you wait,the oil level in the tank will drop and show a low level. My YZ250F smelled like oil and My 07 450 smells like oil,I use DELO 400 ,the smell is coming from the breather tube!
  • 700MX
Posted May 05, 2007 - 06:22 PM
Yea, the breather.....reedy has it concealed...he does not have it wrapping down the frame
  • 700MX
Posted May 05, 2007 - 06:24 PM
Thanks.......yea sometimes my bike smells like an 86' XR600 with ring problems.
  • Hot  47 replies
1998 yz400f will not idle. by trolley
  • Hot  32 replies
  • 0 replies
  • Hot  113 replies
