Synthetic
12 replies to this topic
  • BWB63
Posted May 03, 2007 - 06:03 AM
Got to read all of this to get the full benifit....
Beware of synthetic oil, it can do terrible things to you and your
beloved motorcycle. It will not only leak out of your engine faster
than you can put it in, but it will also cause your oil filter to
clog and implode, dumping debris and dirt into your lubrication
system. It also will make every part of your bike permanently
slippery because of its linear molecular chain dispersion action.
Then it will leak onto your kickstand causing it to retract
automatically, dropping your bike on the ground! But that's not all...
Synthetic oil will round off your gears and spin your bearings. It
will also splatter onto your seat causing your girlfriend to fall off
in the apex of a turn and she'll never ride with you again. Synthetic
oil coats your sight window and your timing window with a whitish
pro-emulsification additive that is both non-removable and highly
corrosive. Synthetic oil will completely leak onto the ground overnight
and your dog will drink it and die.
Synthetic oil will wear out your tires and make your battery leak. It
will give you the desperate need to urinate after you put your full
leathers on and then jam your zippers shut. It will contaminate your
gasoline causing your bike to stall on railroad tracks and accelerate
uncontrollably near police cars. It will make it rain during rallies
and on weekends. It will lubricate your timing belts causing them to
jump teeth and break your valves to bits. Synthetic oil chemically
weakens desmodromic valves and causes the clearances to change every
six miles. Then it melts the black soles of your riding boots right
before you walk across your new carpeting.
While riding past groups of attractive women it will cause both of
your handlebar grips to slip off at the same time so you smash your
windscreen with the bridge of your nose. It also causes your swingarm
to crack, your studs to break, and your rotors to warp, and then it
voids your warranty by changing your odometer reading to 55,555. It
also dries out your wetclutch and wets your dryclutch. It makes your
clutch slave cylinder seal fail in the heaviest traffic on the hottest
day of the year while putting an angry wasp in your helmet for good
measure.
Synthetic oil hides your 13mm socket and puts superglue on your
earplugs. Synthetic oil will scratch your faceshield and make your
gloves shrink two sizes night before trackday. Synthetic oil stole
your neutral and sold it to the Chinese for $1.25. Synthetic oil
will make you grow a tail. Synthetic oil will write long crazy
e-mails to your Internet friends and then sign your name at the
bottom!
  • MartinDKtm
Posted May 03, 2007 - 06:26 AM
The worse is that many peoples belives some of the statement in that text...
  • hondaxrl650
Posted May 03, 2007 - 08:30 AM
Your telling me it is not true .............and I have been living a lie ............:applause: :applause: on
  • mishke
Posted May 03, 2007 - 09:26 AM
reverse physcoligy,'eh?i'm going to get me a case of it-today!:applause:
  • hill5150
Posted May 03, 2007 - 10:29 AM
I'm buying 2 cases................
  • Billahjack
Posted May 03, 2007 - 01:32 PM
Thanks for the info, Shel Silverstien.
I'm using synthetic KTM Motorex blinker fluid for my dual sport kit. My muffler bearings should out last my frame.
  • GIANTac1
Posted May 03, 2007 - 04:45 PM
BUUUURRRRPPPPPPPP! Im a 6 pack into my second case!:applause:
  • Bibleman
Posted May 03, 2007 - 05:11 PM
I knew it! ROTELLA 15-40 RULES:bonk:
  • martinfan30
Posted May 03, 2007 - 06:32 PM
That is phenominally hillarious!!!!!!!!!!:applause: :applause: :p
  • philipstjohn
Posted May 03, 2007 - 07:15 PM
Who here did not know this? :applause: :p :applause: :p
  • hypersthenos
Posted May 04, 2007 - 11:25 PM
Will it damage my lead plated cam?
  • frankstr
Posted May 05, 2007 - 04:59 AM
No wonder I have so many problems with all the rigs I own..:applause: :applause:
I'm going back to straight 50w...:p
  • DiabloCaballo
Posted May 05, 2007 - 10:39 AM
True, but it will help your piston return springs and glow plugs, you just have to run the bike in reverse every once in awhile. :applause:
  • 22 replies
  • Hot  29 replies
  • 9 replies
  • 4 replies
  • 3 replies
