XR600 just died in the arse!
3 replies to this topic
  • pd10913
Posted May 02, 2007 - 08:06 PM
Ok, I've just fitted an FMF Powercore 4 to my 98' XR6, ground header welds, snorkel removed and re-jetted with a 155/68 with the needle in the 4th clip position.
Initial tests all pretty good although may have to go smaller on the pilot jet, just took it for a proper test ride, ran great for 5 mins then just died in the arse.
Engine was still running but only at a slightly higher idle, no throttle response whatsoever but barely idled all the way home, idle adjustment screw made no effect either way, full choke on and off had no effect, and throttle cable seems to be moving all the right bits.
What can it be? have i stuffed something in the carb or have I done something more sinister to the motor, some help please?
  • cleonard
Posted May 02, 2007 - 08:11 PM
Something may have come loose. I have had jets unscrew and once I had the clip fall off the needle. I have had water cause a problem like this. A drop got in the main jet and the engine would do nothing but idle.
  • pd10913
Posted May 02, 2007 - 10:15 PM
My apologies, I have found the problem, the whole link arm assembly in the carb had fallen off, should have checked all this first but I guess I just thought the worst, all sorted!
  • philipstjohn
Posted May 03, 2007 - 03:44 PM
OPPS...:applause: Glad you figured it out...:applause:
  • Hot  186 replies
  • Hot  29 replies
  • 3 replies
  • 4 replies
