650L- Anyone paint their sidepanels black?
12 replies to this topic
  • xrunt
Posted May 02, 2007 - 04:58 PM
Wondering what this might look like with the bike all black and red with no white......? Photos appreciated. Cheers!
  • Rangerfng
Posted May 02, 2007 - 05:28 PM
Take a look at my garage bro. i just did the same thing. i documented everything for all to see
  • Bibleman
Posted May 02, 2007 - 05:39 PM
No, but I saw a picture of one with the air dams painted black and it looked real sharp. Today I got a can of Fusion spray paint made specifically for plastic. I'll let you know how it goes. If it works on the airdams I guess you could use it on the side covers too.
  • Rangerfng
Posted May 03, 2007 - 04:04 AM
Hey bro. yake a look at my garage under the side pannels. I documented everything even my screw ups. it may help
  • COAL RUN
Posted May 03, 2007 - 06:12 AM
How well does the paint hold up to off road use? I have also been thinking of trying this. Another thought was to use numberplate background the kind that comes in larg sheets. Anyone tried this??
  • camoman
Posted May 03, 2007 - 08:23 AM
I used the Fusion paint on my side panels (white),,, looks great....
Laid it down on the trail the other day... still looks great.....
  • asf
Posted May 03, 2007 - 10:40 AM
I painted my R plastics with Fusion. I wasn't impressed with the fusion paint. I prepped the plastics with solvent, degreaser, then alcohol. I painted it in the sun, and it came out pretty uneven. I had to strip it and start over twice.
The can says not to use primer but that is BS. I finally used primer my last round. After using primer it came out great, nice and smooth. Hit it with a low or semi gloss clearcoat and it will take a beating with little or no wear. I've nicked my panels so many times with my boots and there's barely any evidence of a scratch after 1000 miles of street.
  • GIANTac1
Posted May 03, 2007 - 03:28 PM
Nice Bike! I love visiting the Bay area....GO A's! I also painted my side panels black with fusion. I did all the sanding then degreasing then painted. Turned out nice and shiney until......I dropped it. No big deal though, just clean then re-paint! My question is whats a good paint remover?
  • asf
Posted May 03, 2007 - 04:19 PM
Thanks:ride:
I use spray paint remover by a company called Goof Off with excellent results.
  • xrunt
Posted May 04, 2007 - 07:45 AM
Nice look asf!
Thanks for the photo - that's just what my mind couldnt do. Much cooler than white panels!!
  • mrazekan
Posted May 04, 2007 - 10:40 AM
Hi XRUNT!
Here's what mine looks like with the Krylon fusion paint:
Baja Shakedown on FLICKR
I cleaned the plastics with acetone to get all of the dirt and grease off. Then I just sprayed it right on. 5 light coats looked great after drying. The paint is pretty flexible after drying. The tank is a black Clarke.
The bags did rub through the paint. and I ended up with a crack from a rock that started to peel on the "windscreen". I think it looks great!
  • Bibleman
Posted May 04, 2007 - 06:54 PM
I did my air dams and two medium coats did the trick. I didn't want to try scractching the paint to check for adhesion so I gave the back of one a spritz this morning and by this evening it was almost impossible to scratch off. No cleaning or sanding either!
  • xrltim
Posted May 04, 2007 - 07:45 PM
http://i12.photobuck...tim/011_15A.jpg
If you can see this pic you'll see mine. I've had them black for quite a while and taken many spills and scrapes. Holding up well.
