Exhaust Valve adjustment. How do you get a screw driver in there?
8 replies to this topic
  • slowxr
Posted May 02, 2007 - 10:33 AM
What's the trick? I can't get a straight shot at the screw on the exhaust valve.
Special tool?
  • needsprayer
Posted May 02, 2007 - 10:51 AM
Options: Shorty screwdriver, offset screwdriver or one with a really long stem to give you a better angle
  • Billahjack
Posted May 02, 2007 - 01:01 PM
You can back the screw out 1/4 turn or so from the set position and then snug the jam nut with your fingers. Now tighten the jam nut with a wrench or socket and the screw will turn with it. It might take a couple tries to get it. Make sure to double check your work. On the 650R, you want the .006 and .008 to fit but you also want to get the .007 and .009 feeler gages to go in with resistance. In other words, set the valves slight to the loose side.
  • pigryder
Posted May 02, 2007 - 01:03 PM
I know this doesnt help you out now but I bought the motionpro tappet adjusters and it must have cut my valve adjustment times in half :applause:http://motionpro.com...appet_tool_set/
  • XR4DEZ
Posted May 02, 2007 - 08:23 PM
That's a nice tool but can you buy just the 10mm size?
  • pigryder
Posted May 03, 2007 - 03:30 AM
No you have to buy the set and I got it from the MAC tools man that comes to my work and it was actually cheaper than they're web site was
  • DGXR
Posted May 04, 2007 - 07:19 AM
Billahjack is right, if access to the valve covers is tight, you can do the procedure this way with good results. I just remove the tank. It takes more time but it provides wide-open access so you can see everything easily and get the adjustment done properly. My $0.02
  • HeadTrauma
Posted May 04, 2007 - 09:36 AM
What engine are we talking about?
  • slowxr
Posted May 04, 2007 - 12:22 PM
XR650R.
The tips worked. I just loosened the bolt and turned the screw with my fingers. No problem.
thanks
  • Hot  29 replies
Honda XR650L 2017
  • 0 reviews
Fell Off Trailer by usafxr
  • Hot  43 replies
Would a Young Scott Summers still be Competitive today on an XR600R? What would he ride to be competitive today? by Jayzonk
  • Hot  159 replies
  • 22 replies
