03 WR450 starting concerns
3 replies to this topic
  • RaphFoFiddy
Posted May 02, 2007 - 12:33 AM
Hey I have an 03 WR450 with the 03 starter etc, and lately I've been getting some kickback from the kickstarter. On top of that sometimes when I kick the kickstarter locks and won't budge until I press the E-start (typically I'll hear a little click telling me it's OK to kick it over again).
Any one else experience this or have any reccomendations?
Thanks,
Raph
  • xrmarty
Posted May 02, 2007 - 08:34 AM
Woodruff key on the starter shaft? I remember reading somewhere about that, and especially the 03's having particular problems with that. Definitely, find out what's going on! Do more search hear on TT.
  • face_plant
Posted May 02, 2007 - 12:42 PM
is it hot or cold and are u pumping the throttle to start it? it has an accellerator pump in the carb so it pushes fuel into the engine, and causes a liquid lock up. use the hot start give it a kick or 2 then use the easy button
  • RaphFoFiddy
Posted May 03, 2007 - 01:01 AM
I had the Woodruff Key shear during the break-in and it was fixed by the dealer I bought the bike from... Thanks to www.offroad.com I knew about the woodruff issue before It happened to me. That was a rough night first the woodruff key shears at the beginning of the ride, then I hit a deer with my jeep on the ride home...
I typically don't give any gas when I'm kicking it over (still have the original battery in so I don't usually e-start unless she is warm) and the problem occurs regardless of temp. Its rare that I have to give it any throttle maybe a quick 1/8th of a twist when she's really stubborn and cold.
