XT250 Oil seals?
3 replies to this topic
  • swingle12
Posted April 30, 2007 - 05:42 PM
My 1981 XT 250 has started leaking oil at the kickstarter and the front sprocket. It got so bad I quit riding it last year. I'd like to replace the seals, but I haven't been able to find a source. Can anyone tell me where to get a seal kit? Also, how hard is it to replace them? I don't mind pulling the right cover off to replace the kickstart seal, but what about the left side?
  • TOWGOD24
Posted April 30, 2007 - 07:26 PM
HY,YOU CAN GET THE SEALS FROM YAMAHA LES THAN $6.00 A PEICE WWW.YAMAHASPORTSPLAZA.COM. GO TO THE SITE LOOK UP YOUR BIKE.AND LOOK UNDER KICK STARTER AND TRANSMISSION .IT DOSENT LOOK TO HARD. GOOD LUCK I HOPE THIS WILL HELP. 82 XT550
  • kirkswim
Posted May 10, 2007 - 05:11 PM
Yammi still sells them. I removed mine in the bike. Haven't installed the new ones yet as the top end is appart.
  • spokexx
Posted March 12, 2010 - 01:45 PM
i need to replace my oil seal as well, the one on the output/drive shaft behind the front sprocket. Does it just pop right out or does the engine need to come out and the cases need to be split?
