XR650R chain tension?
14 replies to this topic
  • philipstjohn
Posted April 30, 2007 - 06:07 AM
I just adjusted the chain, with the inch or so slack per the manual, then when I took it off the stand and doubled check the slack, it was tight, with maybe a 1/2 inch slack max. I put it back on the stand, and rotated the rear tire. When you rotate the tire half way around, its tight, rotate it a half turn more and it has the 1 inch slack? Any ideas of what should I be looking for, or is this normal? Thanks for the help!
  • bajabinder
Posted April 30, 2007 - 07:25 AM
Sounds like a stretched chain to me. Did you warm the chain up first by taking a short ride before you checked the slack? Chain slack should be checked at different spots just as you've done.
  • philipstjohn
Posted April 30, 2007 - 07:39 AM
Actually, this is how I found the difference- I went out for a short ride, came home and it was tighter then I had set it during adjustment, so I put it back on the stand and did the wheel spin test. I know this is a hard question to answer, but what is a typical life span of the stock chain? The bike is an 06, with approx. 2500-3000 miles on it, if the miles stated of the previous owner is true. The stock sprockets are in place, and there seems to be hardly any wear there. :applause:
  • Billahjack
Posted April 30, 2007 - 02:01 PM
Sometimes links bind a little bit and they do not straighten unless forced to. See of that is going on.
  • philipstjohn
Posted April 30, 2007 - 05:11 PM
I checked the chain and it seems no links are binding. Could it be a alignment issue? :applause:
  • XR4DEZ
Posted April 30, 2007 - 08:53 PM
I don't think the manual says to adjust the chain with the bike on a stand, adjust it with the bike wheels resting on the garage floor. Either on the side stand or leaning the bars against the wall.
  • porterdog
Posted May 01, 2007 - 07:02 AM
From the manual, step one in drive chain slack adjustment:
"Turn the engine OFF. Raise the rear wheel off the ground by placing a work stand under the engine...."
Goes on to say, "Measure the slack in the lower drive chain run midway between the sprockets.
STANDARD SLACK: 20-30mm (13/16-1 3/16 in)."
It IS normal for the chain tension to vary when you roll the wheel around; find the tightest spot and adjust there.
  • philipstjohn
Posted May 01, 2007 - 07:08 AM
Are you sure this is normal?
  • philipstjohn
Posted May 01, 2007 - 03:57 PM
I know this is a hard question to answer, but is there a general rule of approx. how long the stock chain will last before it needs replacing on the XR650R? How many hours/miles? Does it eat up chains like rubber? :applause:
  • XR4DEZ
Posted May 01, 2007 - 06:43 PM
Usually get 3K(desert) miles out of a chain and sprockets. I use the Xring DID and steel Sunstar sprockets.
  • XR4DEZ
Posted May 01, 2007 - 06:51 PM
Check your manual page 125 paragraph 3 tells you to adjust the chain with the bike on the side stand.To me at the middle of the swingarm on top there should be a close 3 finger space between the chain and the swingarm. This allows for hard hits that suck up the chain slack so it does not tug on the counter shaft sprocket.
  • philipstjohn
Posted May 02, 2007 - 07:04 AM
I have about 3K on the original chain and sprockets- have not measured the chain to see if it is within the limits yet, and the sprockets look great. About half the miles are road miles, with the remaining off road, but not hard miles in my opinion. I have not done any serious racing or hard riding, just getting used to the bike in the local state park. Do the upper end chains like a DID ERV2 or 3 last longer?
  • XR4DEZ
Posted May 02, 2007 - 05:38 PM
The DID VM Xring and the Sunstar sprockets last as long (for me) as the ERV or Sidewinder at a lot less money. If your sprockets look good the chain probably is still OK, you'll have to measure to be sure.
  • porterdog
Posted May 03, 2007 - 04:26 AM
I've seen that on several different bikes and when speaking to other bikeguys they weren't the slightest bit surprised.... Maybe normal isn't the right word.... It's not uncommon?
  • porterdog
Posted May 03, 2007 - 04:27 AM
Is that the owners manual? The stuff I quoted came from the factory service manual, which talks about the decompressor assembly on p125 :applause:
