yz450f won't crank after rebuild high comp. piston
6 replies to this topic
  • martman-2000
Posted April 26, 2007 - 07:12 PM
I have ask this earlier but can't find the post. I installed a je high compression piston in my 04 450f today and it will not even attemp to crank. the cam timing is perfect, the compression is great, and the plug is firing outside the cylinder (ngk cr8e) the carb is great the bike cranked great just before I did the topend but now will not even backfire.
HELP PLEASE!!!!!!!!!!
  • 642MX
Posted April 26, 2007 - 07:26 PM
Engines need 3 things to run. Spark, compression, air/fuel. One of the 3 your missing.
  • BergArabia
Posted April 26, 2007 - 08:07 PM
Has spark..
Has compression..
Had a good working carby but perhaps something happened in reasssembly at this air fuel mixture point..
Posted April 26, 2007 - 08:51 PM
Engines need 3 things to run. Spark (at the right time), compression, air/fuel. One of the 3 your missing.
Your troubles are most likely the result of bad fuel, a carb problem, or an old plug, but it might be worth your time to check the flywheel key.
  • bpb
Posted April 27, 2007 - 08:34 AM
check stop switch button
  • martman-2000
Posted April 27, 2007 - 03:05 PM
Thanks to all. It is fixed. The flywheel key was the problem. It had fallen out and the ignition timing was off.
Thanks for all the help.
  • steve_97060
Posted April 27, 2007 - 03:09 PM
and his legend continues to grow...
  • 10 replies
  • Hot  36 replies
