Valve Shims
2 replies to this topic
  • Mvsvette
Posted April 25, 2007 - 09:15 PM
I have an 06YZ450F. The other day at the track the screw that holds the air filter on came off and went into the cylinder. The damage to the valves was bad, both exhaust demolished and 2 intakes bent. I used a dremmel to clean up the piston and I'm in the process of installing new Kibblewhite valves and springs. My question is, can the valves be shimmed with the head on the work bench or does it need to be on the engine. If it dosn't need to be on the engine I'll drop it off at the shop to be shimmed. Thanks,in advance.
  • Ducksgoquak
Posted April 25, 2007 - 09:23 PM
Pretty sure i did it myself with the head off. It's been a while and i had help but i think that's correct. I'm sure someone else can tell you for sure though.
Posted April 25, 2007 - 10:02 PM
You can do it that way, but you'll want to double check them once more after the head and cams are completely torqued in place.
  • Hot  28 replies
  • 9 replies
  • Hot  36 replies
Motocross
  • Hot  491 replies
