Acerbis Front Fender Install Snag...
7 replies to this topic
  • jct9841
Posted April 25, 2007 - 12:07 PM
all,
Trying to mount this thing (acerbis universal supermotard front fender) on an '01 XR650L but the wiring harness is in the way (there is no trough for it as in the stock fender).
I'm thinking of adding spacers? Anybody else run into this?
Other solutions?
Thanks in advance,
JT
  • drtlvr
Posted April 25, 2007 - 12:35 PM
yes I ran spacers just some plastic washers will do,I think they were a 1/4" don't try to move the harrness,I tryed that and it is way to snug,you might have to trim the back of the fender to clear the headpipe
  • McQueen278
Posted April 25, 2007 - 01:32 PM
I installed the same fender on my 07 Xr650L and I just unplugged the wiring and ran it over the bottom triple tree. On mine there was more than enough slack in the wiring. It took about fifteen minutes once you take off the front number plate.
  • kelleyseiler
Posted April 25, 2007 - 01:41 PM
all,
Other solutions?
Thanks in advance,
JT
Here's what I did for the same problem.
I made a aluminum plate and 1inch stainless spacers. Looks good also. This pic makes it look as though there is a trough but there is not.
  • Rangerfng
Posted April 25, 2007 - 04:20 PM
i did not but did need to use spacers for another bike looked good
  • jct9841
Posted April 26, 2007 - 03:25 AM
Thanks for the quick replies! I lilke the plate Kelley made - wish I could fabricate one.
I'll try the harness re/route or spacers.
later, JT
  • jct9841
Posted April 28, 2007 - 06:20 AM
I ended up doing the wiring harness re-route. Plenty of slack.
The fender came with a triangular piece of plastic with two posts sticking out.
What is it?
JT
  • McQueen278
Posted April 30, 2007 - 05:45 AM
What is it?
JT
Glad the re-route worked out for you, seems like the easiest way. Also, I'm not sure what the triangular piece might be, mine fender came without it.
  • 9 replies
  • 22 replies
Honda XR650L 2016
  • 0 reviews
Washington
  • Hot  32 replies
  • 4 replies
