07 yz450 locked up
28 replies to this topic
  • flmx4
Posted April 24, 2007 - 06:06 PM
I've seen 2 2007 yz 450' s lock up in the last week. Both started to make a clicking noise and by the time they were shut off they both locked up. Just tore one apart to find valves, head , cylinder, clutch, stator,cam chain, flywheel , all perfect. Rod moves on the crank but the crank is stuck like chuck. Any body else see this yet.
Posted April 24, 2007 - 08:51 PM
You're the first. Now you need to elaborate on the cause, since you have the engine apart.
  • Polar_Bus
Posted April 25, 2007 - 04:19 AM
Yup, I agree too many details missing to get all nerveous. I know of about 100 current YZF owners, and the only time the engines blow for no reason (other then never changing your oil), is when the bike gets crashed, layed over on it's side, throttle pinned in the dirt WO with the engine running. Oil cavitation eventually kills the engine.
  • Ranger18
Posted April 25, 2007 - 06:47 AM
[quote name='Polar_Bus']Yup, I agree too many details missing to get all nerveous. I know of about 100 current YZF owners, and the only time the engines blow for no reason (other then never changing your oil), is when the bike gets crashed, layed over on it's side, throttle pinned in the dirt WO with the engine running. Oil cavitation eventually kills the engine.[/QUOTE]
I think I just barfed. That sounds like a terrible way to go.:applause:
Posted April 25, 2007 - 07:56 AM
And because the YZF is a dry sump, it has to be beyond 90 degrees laid over to starve for oil, at least until half the oil has been pumped into the engine and not retrieved. Plus, both the rod and main bearings can survive on residual oil for a remarkably long time without damage. The piston and cams would be the first to suffer in a situation where oil flow was lost.
flmx4 is a CRF rider, and unless he comes up with a little more solid information than he's offered I see a trolling infraction in his future.
  • WB450
Posted April 25, 2007 - 09:19 AM
What is a "trolling infraction"?
Posted April 25, 2007 - 09:44 AM
http://www.thumperta...faq_board_rules
"No trolling. Trolling is starting threads or replying to posts with the purpose of getting a rise out people. For example, starting a thread titled "Yamaha Riders Suck" in the Yamaha bike forums."
Infractions:
http://www.thumperta...raction_warning
  • WB450
Posted April 25, 2007 - 09:57 AM
:applause: I see.
  • 426_kid
Posted April 25, 2007 - 12:47 PM
I was going to say maybe the crankshaft bearings but gray says they'll last with risidual oil so idk?
  • flmx4
Posted April 25, 2007 - 02:18 PM
You people crack me up ! I ride CRF 's so I'm just starting crap ! I only had time to tear it part of the way down the other night, and then I thought I would start a post to see if anyone else had ever encountered this yet. I'm going out to the garage right now to tear the bottom end apart. I will then reply to this again barring I don't need some kind of security clearance to let people know what I found. I work on every type of bike and could care less what anybody else rides.
  • bboyce
Posted April 25, 2007 - 02:33 PM
Pictures!! :applause:
Posted April 25, 2007 - 03:50 PM
No problem. Hundreds of inquiring minds are eagerly awaiting your findings.
You might look into the gear train that drives the starter/oil pump, etc.
  • WB450
Posted April 25, 2007 - 06:55 PM
Easy, we just want to know is up, it's all news to us. Plus I have one!:applause:
  • 6fiddy
Posted April 26, 2007 - 11:20 AM
The penalty for "trolling" Is Death by Yamaroost. We tie you a CRFwhatever and back up to you and hit the gas WFO. Seriously, I am sorry this happened to you and thanks for sharing your findings. These type of posts are very valuable to us if they prevent an event from happening. Thanks!
  • flmx4
Posted April 26, 2007 - 03:52 PM
The bolt that holds the top bearing keeper on the left side of the case, snapped the head off and the keeper wedged itself between the crank and the case. The head on the bottom keeper was 2/3 of the way off and ready to let go. The cases maybe salvageable, but any crank that stops abruptly is bad if you ask me. It really looks like it was a faulty bolt, but I'm not a metalurgist. Going to get ahold of somebody at Yamaha tomorrow. I hope it's not a bad batch of bolts.
Posted April 26, 2007 - 04:01 PM
I always hate when such minor failures are caused by such big, expensive parts [/sarcasm] :applause:
  • PATHPOUNDER
Posted April 26, 2007 - 04:11 PM
Still no reply huh..???
  • marktm200
Posted April 26, 2007 - 04:12 PM
I have seen that problem with 07 yfz450 & raptors quads they've been doing this for years. Check your bike on the side of the fender next to 450. If its one of the defective models (for the quads anyways not sure if it holds true for bikes) it will say yamaha.
Hope i can help
  • Troutman
Posted April 26, 2007 - 06:29 PM
Any pics? For people who would like to know what to look for.
  • WB450
Posted April 27, 2007 - 07:09 AM
I would love to know more, pics.
  • 0 replies
  • On January 15, 2017
  • Hot  38 replies
