TM Parts cross over thread
30 replies to this topic
  • adman_glazer
Posted 24 April 2007 - 11:46 AM
I have had my TM for almost a year now (2001 250 MX 2T). What I was wondering is if everybody who has knowledge about TM's could post any cross over parts they know of. I have the Paioli forks and when I blew my fork seals while out riding we were able to replace the seals and bushings with stock honda parts. Any other stuff would be greatly appreciated. I would like to mostly stuff like plastic, seat, brake pads, air filters, levers etc.
Thanks a million guys
  • metal_miracle
Posted 24 April 2007 - 12:48 PM
i found that the waterpump seal you can use from a cr250 02-07
rear fender is from a kx125//250 99-02 (TM 80-300 00-07)
Rear fender form 04 is tms own
front fender was from a RM 88-98 (tm 80-300 91-97)
front fender was from a kx 94-02 (tm 80-300 98-01)
Fork covers honda
i used pipe springs from an rieju
honda break lever
ktm radiator cap
the older tms whit wire i used sym scooter levers
i used honda seat cover on my tm94
motard front fender think you can use derbi and reiju fender
  • WILD_FX
Posted 24 April 2007 - 02:48 PM
Great thread ..
02 to 06 530 TM clutch
02 YZ 426 and WR
Any one know if there is a cross over for the chain slider?
  • jimg1au
Posted 25 April 2007 - 03:46 AM
hi
i would like to know is there a crossover for the front sprocket for a tm300en 2002.also how much oil goes in the gearbox
cheers
jimg
  • metal_miracle
Posted 25 April 2007 - 05:01 AM
chain guide rubber match honda
splas lip same as honda
think i used 0.7l same as any other 2stroke in the gearbox
  • WILD_FX
Posted 25 April 2007 - 07:10 AM
is the chain slider the same for the 2005 530 ?
  • metal_miracle
Posted 25 April 2007 - 08:10 AM
i dont know the slider. but the guide as i said
  • adman_glazer
Posted 29 April 2007 - 03:40 PM
So here is a few parts to add to the list.
Kickstart lever....2003 Honda CR 250 fits great. Washer needed to be replaced. (I snapped mine with a little half kick)
Mud flap.....2003 Honda CR 250 is an exact match
Some others already posted
Fenders off KX 250 will fit coressponding year
Water pump gasket is a Honda part
Pretty sure you can use Honda Brake pads on the rear
Keep posting I am hoping I can cross reference most or all of my bikes breakable parts (stuff you tear up while riding) It would be nice to bring some spares that aren't worth $500 - $600.
  • LukeW
Posted 29 April 2007 - 11:31 PM
TAKEN FROM DIRTBIKEWORLD
06' 300
Front wheel bearings same as WR 450 PN:6904LLU/2AS (NTN Bearing)
Chain rollers bearings same as skateboard wheels PN:608LU (NTN Bearing)
2T Exhaust O Rings are $5 from the dealer
Air Filters same as Honda CR250R 96-02 or Yamaha WR500
Connecting rod is a Pro-X Honda CR250R 02-07 PN:03.1322 (Pro-X)
Little end bearing same as Honda CR250R 02-07 PN: 91015-KSK-731(Honda)$15
Genuine little end bearing $48
I've just got a Wossner Piston PN:8213D (A/B/C) for $170 (Bikes & Bits - WA)
Genuine Vertex is $398
I don't Know if this is a good or bad thing-Front fork seals same as 89' KX 125/250/500, 00' XR650, 89' RM 125 cost $33
Don't know what genuine Ohlins fork seals cost
Also keep an eye on the collar in the lower shock bearing, it's not case hardened and wears pretty quickly genuine $14. The bearing is DL1812 (Nadella) $13 local bearing shop
NOT SURE WHAT YEAR MODEL THIS REFERS TOO.
Front wheel is CR250 06, you'll need the Honda axle, nut and a 270mm disc.
KTM:
Radiators
Radiator guards (part # is on the guard)
Footpegs
Front brake caliper
Speedo (mxc )
Grips
carb (early sx)
jets
Honda:
piston
little end
ring
front brake lever
front master cyl
rear master cyl
rear caliper
throttle housing
throttle cable
throttle rubber cover (TMs don't come with these)
seat cover (07 CR250)
pipe (ProCircuit 04 CR250 with minor mods)
(OHLINS)
the fork seals are the same as yamaha YZ's 48mm forks
the front brake leaver from memory is a YZ/KX unit
  • Caravan Monster
Posted 03 May 2009 - 03:32 AM
Dirt rider forum:
http://www.dirtrider...ead.php?t=42437
Anyone got parts cross over information on the 2001 125 MX? I'm re commissioning one at the moment.
  • sidewayskid
Posted 03 May 2009 - 06:28 AM
01-02 250,300 sparkarestor 02 KX 250 Watson has had shifters made.
  • Caravan Monster
Posted 03 May 2009 - 11:52 PM
2001 125 MX: the cast part of the swingarm is virtually identical to that on an early nineties CR500. The linkage parts are identical and will swap over.
  • sidewayskid
Posted 04 May 2009 - 11:10 AM
The rims are Yamaha or KTM. Morads are available in silver or blue.
  • chaser
Posted 04 May 2009 - 01:09 PM
I would like to use a TM designworks rear chain guide. Anyone know what bike/model would fit my 03 125?
  • widebear
Posted 04 May 2009 - 06:18 PM
gasgas shifters will interchange
  • Caravan Monster
Posted 06 May 2009 - 11:53 AM
chaser said:
The silencer or spark arrestor for a 1999-2007 125 is the same as a Kawasaki KX 125, 1996-1998. I have used both FMF and Pro Circuit with success.
That's useful to know. I need to find a much quieter silencer for my 2001 125 MX, to meet decibel (noise) regulations, to race in hare and hounds. Any recommendations for a quiet silencer which would fit? The TM enduro silencer is very expensive (sterling£203 + tax. Well over USD$300 , I think). There is no market for quiet MX silencers/ spark arrestors in the UK, so I am not familiar with what is available.
Comment: Despite the horror stories about wildly expensive TM parts, I found the engine parts to be very reasonably priced, and the customer service from TM UK is excellent. Just my 2 cents.
  • jfgjr
Posted 06 May 2009 - 01:18 PM
Pro Circuit has them (spark arrestors) in stock around $150.
  • trailridercharlie
Posted 13 March 2010 - 06:58 AM
How about a cross over for an air filter for a 97 125 TM Any info?
Thanks
Charlie
  • trailridercharlie
Posted 13 March 2010 - 08:02 AM
Reliable source claims a 125 CR Honda filter will fit my 97 125 TM
Also a 97 KX seat will fit this bike.
Thanks and keep this info building!
Charlie
  • yz133rider
Posted 16 March 2010 - 03:26 PM
Anyone know what size forks the '03 ohlins were on 250 mx models? Im hoping 48mm since I ordered a set of 48mm seals off of a yz to replace my blown seals.
If you enjoyed reading about "" here in the ThumperTalk archive\, you\'ll LOVE our community. Come join ThumperTalk today!
