New WR450, Fuel spitting out tank vent
5 replies to this topic
  • don319
Posted April 24, 2007 - 04:09 AM
My new WR spits fuel out the tank cap vent hose. How can I fix it? The 1-way check is in the proper orientation and the hose is not plugged or kinked.
Thanks
Don
  • woodsk
Posted April 24, 2007 - 04:28 AM
previously the WRs came with a check valve in the hose. not sure about the 07s if it is there make sure it is not backwards. and if not then I would get one.
  • Paradiddle
Posted April 24, 2007 - 11:55 AM
Hey Don!
Mine (and several others) did it too!
I cut a small piece of air-filter foam, and installed it inside the cap vent (take the cap apart- 3 screws). Be sure to use air-filter, or fuel rated foam.
I guess the fuel squirts in faster than it can get out, so the foam blocks a lot of the splash. No more leaks.
Lynn
  • don319
Posted April 24, 2007 - 01:51 PM
Thanks, that is exactly what I was wondering about. I will give it a try.
  • 450high
Posted April 24, 2007 - 01:54 PM
how fulls the tank ?
  • gregwr450f
Posted April 24, 2007 - 02:40 PM
get the dealer to fix it.
