IMS 07 YZ450 tank onto 07WR with no mods!!!
11 replies to this topic
  • fitzy
Posted April 23, 2007 - 04:12 AM
Did a search and found people have been fitting these tanks with a few mods either to the seat or spacing the rear mount on the tank to get them to fit properly onto the WR's
Went to put mine on today and found the same thing. Seat wont line up to get the bolts in.
Dug a little deeper into it and all you have to do is fit 2 washers under the seat locating pin on the tank. The flat black washer thing.
By lifting it up about 3mm, the seat will slide on and everything lines up perfect. So don't go cutting your seat up as some have suggested:eek: :applause: no need
Hope this helps a few people out. You do still need the YZ shrouds though
Cheers:thumbsup:
  • custom-cruiser
Posted April 23, 2007 - 06:54 AM
Pics????
  • xrmarty
Posted April 23, 2007 - 08:13 AM
I just put mine on (part#117327 ) It is listed by IMS for 07 both the yz and wr. If your going to put it on the wr you will need to use YZ radiator shrouds too.
  • Greenroom
Posted April 23, 2007 - 08:52 AM
Very cool keeping the black tank. thanks for the heads up. :applause:
  • msgbean
Posted April 23, 2007 - 09:02 AM
xrmarty if you could I would like to see the other side please with the seat on preferably.
  • xrmarty
Posted April 23, 2007 - 09:58 AM
no sweat. I'll do it in a few...
  • xrmarty
Posted April 23, 2007 - 10:40 AM
Here's a few pix of my tank. Black IMS tanks for the 07 are on special order basis at this time. I'm sure that will change soon as time goes by.
Fancy shmancy gas cap from Project 321. (this one actually came off my XR, a blue is on the way:busted: )
You will need a longer fuel line. As you can see in the picture the fuelcock is way forward and the original fuel line won't reach
  • BikeDestroyer
Posted April 23, 2007 - 12:35 PM
You won't need a longer fuel line.....just turn the petcock around....it will be more difficult to turn on/off, but works just fine.
  • WR_Dave
Posted April 23, 2007 - 12:37 PM
I used a fuel petcock from a '02 WR 426 and put it on the IMS tank so the outlet port is in the right direction. It was pretty cheap from the dealer. WR Dave.
  • msgbean
Posted April 23, 2007 - 01:03 PM
xmarty is that a 3.1 Gal?
  • SXP
Posted April 23, 2007 - 05:11 PM
The air box vents, where did you get them from? Do they make a difference in power? And what do you do when you wash the bike to keep the filter from getting wet?
  • xrmarty
Posted April 23, 2007 - 09:36 PM
thanx dave. I will definitely check out this option
yes
I made them at my garage
I don't know yet. I just rejetted the bike last night. I'm gonna take it to Doves Springs next week for it's maiden ride. (bought the bike 2 weeks ago)
I will have to figure that out as time goes (never washed the bike yet). I'll start by being very careful. If that doesn't work I may have to plug/tape them off:banghead:
