Weird Jetting problem
26 replies to this topic
  • WR450RICKO
Posted April 30, 2007 - 12:27 PM
#21
stock main and turn the air screw out 2 turns with needle in position 4.
48 pilot
works for me
Good luck
165 is stock for my 06' wr450
I installed the GYTR AIS removal kit per the instructions. The needle and 48 pilot jet are the only things that have been changed in the carb. I did install a Zip Ty air/fuel screw and have it turned out 2 3/4. I ride from sea level to 5000' in 50 to 90 degrees. My bike runs great with smooth power through the range and no decel popping. Everything else is stock.
  • CRF45OX
Posted May 02, 2007 - 02:47 AM
#22
the fuel i use is 98% octane, what octane fuel does everyone else use and with what size main jet at low altitudes and cold temperatures?
I think this will be a worth while comparison.
  • WR450RICKO
Posted May 03, 2007 - 09:47 AM
#23
91 or 92 octane
  • bandit99
Posted May 03, 2007 - 10:03 AM
#24
91 or 92 octane in the states
  • CRF45OX
Posted May 04, 2007 - 12:45 AM
#25
hmmm, this weird jet problem is starting to make more sense now.
  • chrispy1202
Posted May 18, 2007 - 05:51 AM
#26
Do you notice your head pipe to be hotter than normal. Maybe too lean. i have the 170 main, blue needle in third from top position, with yz exhaust and run 91 or 94 octane and my '03 450 rips.:)
Cheers
Chris.
  • CRF45OX
Posted May 18, 2007 - 09:21 PM
#27
no my pipe does not glow and i run 98% octane with a 160 main and its perfect - dosent like fuel with a lower octane rating though - you can feel it start to get lean in the midrange.
