Front brake question?
4 replies to this topic
  • 14hockey
Posted April 22, 2007 - 05:19 PM
I just got back into riding last year after 10 years . I ride a Wr450f and I flip the clutch lever to the right side because I was born with one Arm .I use a prosthetic arm on my left side ,No problem.I used to put the front brake on the back side of the throttle but now when I do that the reservoir on the brake is upside down and unusable .Is there a wheel drum conversion or a reservoir that can be mounted out of the way and use cable to the brake lever.Or maybe a horizontal reservoir for front brake use.I have talked to a few people but all I've gotten are theories .I'am looking to remody this soon ,any help would be appreciated.
  • baja4lif3
Posted April 22, 2007 - 05:22 PM
You dont need a front brake! its a four stroke thats why we have engine breaking.
  • 14hockey
Posted April 22, 2007 - 08:48 PM
Ya ,I know you don't need a front brake until you need a front brake .
Some of the mountains we go on and Down would be more easily handled if you could use a front brake when you need it.
  • BigIan
Posted April 22, 2007 - 10:22 PM
Could you run both brakes off the foot pedal?
  • waynus
Posted April 22, 2007 - 11:08 PM
've only got theories for you but u may not have heard them
1. Get a rekluse
2. Use a KTM clutch lever for your front brake. You'll need to check that the bore size is similar
3. Get a brake lever off of a sportsbike that has a remote reservoir and get it resleeved to the same internal diameter of the WR.
I use front brake 90% so I know what you mean. Good luck
