flat spot YZ450 2006??
4 replies to this topic
  • ausimoto
Posted April 22, 2007 - 02:16 AM
Hi guys
a good mate of mine just fitted a vortex to his bike and re-jetted his carbi and now it has a flat spot when accellerating. I adjusted his air/fuel screw and put a smaller jet in it with no luck. If anyone could asist in rectifying this problem would be great:crazy:
cheers
Ausi
  • Fastest1
Posted April 22, 2007 - 05:59 AM
Do you mean a Vortex ignition? Does it have multiple maps? Or are you referring to a power now? Have you tried the jetting that was working before any other changes.
Posted April 22, 2007 - 08:11 AM
For one, your description of where and under what circumstance the "flat spot" occurs needs a little more detail.
Try using a baseline of 45/165/needle in #4/2 turns out, and see how it acts. If there are multiple ignition maps available on the Vortex, try a different one. If all else fails, try the stock CDI again to isolate the problem.
If you expect the bike to be able to take full throttle on a sudden snap form idle, you're dreaming. You can improve on the response a stock '06 is delivered with, but no big 4-stroke is ever going to do that without giving up something else.
  • ausimoto
Posted April 23, 2007 - 02:50 AM
It is a vortex ignition, and the flat spot occurs when you snap the throttle and the bike is that bad it stalls the engine. I will try the stock Ignition back on it to isolate the problem.
Thanks guys i will let you know how i go.
ausi
  • ausimoto
Posted May 15, 2007 - 11:21 AM
Guys
He thaught that by dropping the bike into a dealer it would fix the problem, but no after spending hundreds of dollars still a dead spot not as bad. Thanks for your advice guys.
  • On January 15, 2017
  • Hot  28 replies
  • 0 replies
  • Hot  50 replies
