Why does a WR have a 18" rear?
15 replies to this topic
  • bangmika
Posted April 21, 2007 - 10:27 PM
I was reading up in dirt rider about the new WR 450 and they said yamaha kept some of the goodies like the rear 18" rear wheel and bla bla. I'm relatively new to motoing so why is that a goodie as they say? What is the advantage to having a smaller tire in the rear rather than the bigger rear that the YZ sister has giving more clearance (or does it)? And on another question I have, in that same article they claimed that they kept the wide-ratio five speed. However on Yamahas website they advertise a constant mesh 5 speed for the 07 WR. Who had the facts straight yamaha or dirt rider? What does wide-ratio mean compared to the yz-f trans, and what in the world is a constant mesh transmission?
  • dominator426
Posted April 22, 2007 - 12:05 AM
Most if not all manual transmissions are of the constant mesh type. The transmission gears are always in mesh and rotating, and not rigidly connected to the shafts. A wide ratio tranny's gears are more widely spaced, so there is more rpm drop when you shift up, but it offers more speed range with the same number of gears... So the WR has a constant mesh wide-ratio 5 speed transmission.
18 inch rear wheels use taller tires which are more forgiving and offer more traction in rough terrain, where the WR was intended to be operated. The 18 inch wheel/tire assembly is also heavier than the 19.
  • WR_Dave
Posted April 22, 2007 - 04:55 AM
As Dominator said , all transmissions are constant mesh otherwise we would all be grinding our gears on every shift. The WR's wide ratio gearing is designed to be good in applications from slow single track to wide open desert racing. The YZ is designed more for track use where the gearing would be more concentrated on keeping the shift points closer together for a motocross track. The 18 inch rim actually holds a tire with a greater outer circumference than the 19 inch tire. The 18 inch tire has a much wider sidewall to absorb the impacts of rocks, roots , logs etc. that are not usually found on a motocross track. That's why the 18 inch tire and rim assembly is a bit heavier than the 19. WR Dave.
  • timcook
Posted April 22, 2007 - 08:18 AM
The 18 inch wheel is virtually unchanged throughout the WR's history. I run a 18 from a 426 for my paddle tire at the dunes on my 05 WR450. Lets hope Yamaha doesnt change it for a long time. The 18 is much better for off road and paddle tires than a 19 motorcross wheel.
  • xrmarty
Posted April 22, 2007 - 08:34 AM
good thread...I've pondered the question of 18" vs. 19" many a time
  • SPLATT
Posted April 22, 2007 - 11:36 AM
On the other hand the 19" has a lower profile so it will roll less in the corners.
Steve
  • ARin
Posted April 22, 2007 - 11:46 AM
Steve
and pinch flat more on rocks.
for offroad riding, the 18 is the way to go.
  • SPLATT
Posted April 22, 2007 - 04:58 PM
Yeah there is that. I prefer the 18" off road myself.
Steve
  • witdogg
Posted April 22, 2007 - 05:00 PM
Do you know the weight difference?
  • bangmika
Posted April 22, 2007 - 05:01 PM
You guys are a great. Thanks for your help. Now the big step...who wants to trade me their wr for my yz :applause:
  • WR_Dave
Posted April 22, 2007 - 07:26 PM
I don't know the exact weight difference , but I beleive it is in the 2-4 lbs range depending on the thickness of tube being used. Other guy's on this site might have a better idea.:applause: WR Dave
  • witdogg
Posted April 22, 2007 - 07:27 PM
I don't know the exact weight difference , but I beleive it is in the 2-4 lbs range depending on the thickness of tube being used. Other guy's on this site might have a better idea.:excuseme: WR Dave
Thanks for getting back to me. :applause:
  • SJMC_DON
Posted April 23, 2007 - 12:23 PM
This is also why you'll find 2 rimlocks on the WR 18", there was thread in here a while back where people were stating you did not need two rim locks... the heavier weight means more rotating mass therefor the need for the 2nd rimlock, plus if you get a flat out in the middle of no where it's a little easier to keep the tire on the rim..:applause:
  • dmarmaduke
Posted April 24, 2007 - 05:27 PM
the 18" rim with the tire weighs 23.5 lbs. and the 19" combination weighs 22 lbs. this dosn't sound like a lot but I was able to shave 12.5 lbs. off of my WR 1 lb. at a time, its basically a YZF with electric start and larger fuel capacity.
  • Punisher660
Posted April 25, 2007 - 12:12 PM
What year YZ? I might entertain that offer :excuseme:
  • dmarmaduke
Posted April 25, 2007 - 06:33 PM
its a 06 WR that weighs 236 lbs dry.
