Help with my ajustable fuel screw tonight please.
5 replies to this topic
  • djtroy
Posted April 21, 2007 - 04:28 PM
Just bought a couple of Pro Circuit Adjustable Fuel Screws for my 07 450f and my cousins 2007 crf 150r I was wondering if there are any tips/tricks to install it.
I have a race tommorow (sunday( so I was wondering if this is something I could do tonight easily?
Posted April 21, 2007 - 04:43 PM
If you have a screwdriver small and short enough to remove the OEM screw without rolling the carb in its mounts, it's easy enough. Remove the stock screw, spring, washer, and O-ring (the O-ring likes to stick in the bore) and assemble them onto the new screw in that same order. Lube the O-ring by rubbing it between your lightly greased fingers.
If you lack that short screwdriver, pull the tank, take the ties off the hot start cable and TPS harness, and remove the top engine mounts (we're talking about the 450 here). Then loosen the carb isolator and the air boot clamp, and roll the carb to the right so that you can get at the screw with something longer.
  • djtroy
Posted April 21, 2007 - 04:56 PM
Is it a philips head screw in there or a flat?
Thank you sir
  • djtroy
Posted April 21, 2007 - 06:07 PM
I did both in about 30 min, Thanks
  • almostinvincible119
Posted April 21, 2007 - 07:07 PM
new parts are for wednesday (or a practice day)...it doesnt matter what it is
  • DPW
Posted April 22, 2007 - 07:24 PM
Yeap....:applause:
Motocross
  • Hot  491 replies
  • Hot  47 replies
  • 0 replies
