my sprocket finished?
6 replies to this topic
  • albertlui
Posted April 21, 2007 - 07:54 AM
06WR450 after 7500KM
do i need to relpace the front sprocket immediately? :applause:
  • Kasjok
Posted April 21, 2007 - 08:04 AM
I would like to know how do you understand that now it`s time to change your sprockets and chain? Of course you can`t wait until chain snaps, but still...
I just replaced my chain with D.I.D X- ring chain and sprockets with PBR sprockets. Are these quality products?
  • 642MX
Posted April 21, 2007 - 08:33 AM
Your front sprocket looks like its had better days. IMO you should replace them as a set (chain, rear sprocket, front sprocket)
  • 642MX
Yep, those are good products. :applause:
  • albertlui
Posted April 21, 2007 - 09:35 AM
but the rear sprocket looks can run some more thousands of KM
  • El Marko
Posted April 21, 2007 - 09:40 AM
If one needs replacement and the other is worn as well, both should be replaced.
Sprockets are meant to be replaced regularly. They're not family heirlooms. The same with chains.
  • msgbean
Posted April 21, 2007 - 07:16 PM
But at a minimum you should replace the front sprocket before you break the teeth off.
