New YZ 400F Rider question
5 replies to this topic
  • YZRider400
Posted April 20, 2007 - 05:19 PM
I`m a new rider and am learning the ropes slowly. What is the ribbed knob by the carb, I`m assuming it is the idle adjustment, if so is it just a stop adjustment or is it low speed jet adjustment. If it is a jet adjustment what should it be.
Thanks for any feed back
  • gbalias
Posted April 20, 2007 - 05:40 PM
its a stop adjustment for the throttle wheel.
  • 642MX
Posted April 20, 2007 - 05:59 PM
Yep, its an idle adjustment screw. Turn it in to increase your idle and turn it out to decrease your idle.
  • 1rkcooper
Posted April 20, 2007 - 06:32 PM
Check out the common threads at the top of this forum there is a ton of useful info there. May not cover this question but has much info in it.
  • YZRider400
Posted April 21, 2007 - 03:47 AM
Thanks for the info
Posted April 21, 2007 - 07:06 AM
If the knob seems difficult to turn, remove the throttle cable cover from the right side of the carb and hit the threads of the actual stop screw with some dry moly spray lube.
Sounds like you may also want a manual:
http://www.yamahaown...ook.com.au/?r=0
