Oil Filter and Mobil 1 @ Walmart
7 replies to this topic
  • Vezi
Posted April 20, 2007 - 06:12 AM
For those of us (XR650L) using the fram CH6015 they are sold at Walmart for $4.94 ea which is less than the local bike shop. They also sell Mobil ! Racing 4T Fully Synthetic 10w-40 oil for $8.23.
  • Kawabuggy
Posted April 20, 2007 - 06:38 AM
You can also get the Wix oil filter-which is a much better filter than anything Fram has ever even dreamt of making for about $6 at any O'Reilly auto parts.
They also have Lucas semi-synthetic specifically for 4 stroke motorcycles for $6.23 a quart.
In regards to Fram filters-do a search on the internet about them. There was a study done on automotive oil filters that shows that Fram is one of the lowest quality filters produced in an independent study of over 300 different filters. I don't know if that carries over to the motorcycle filters, but I will not use Fram in anything I own. Heck, I wouldn't use Fram in a car I was trying to dump on my worst enemy. .
  • Vezi
Posted April 20, 2007 - 06:50 AM
I, use Wix which is a "Napa Gold" in all my vehicles and yes Fram sucks. The Fram cartridge filters are fine to use in bikes. We don't have O'Reilly's in NV but we do have Napa. The Mobil ! 4T is specifically for bikes.
  • goblin127
Posted April 20, 2007 - 07:22 AM
I've heard the cartridge filters are fine also,probly made by some one else or vise versa.
  • ajones
Posted April 20, 2007 - 07:24 AM
I have a slightly off topic question. I went to change my oil this year and one of the allen bolts to get to the filter is too worn to remove. I bought new oem bolts to replace it but.... What is the best way to remove the old bolt?
I had one friend tell me to take a slightly oversize allen and tap it in with a hammer, remove it, and then replace it?
Good advice? other options?
Thank you,
AJ
  • InternalCombustion
Posted April 20, 2007 - 05:43 PM
Vezi, thanks for the heads-up on Mobil One, 4XT at Walmart, at a good price, no less!
You da man.
  • paul246
Posted April 21, 2007 - 05:23 AM
Thank you,
AJ
AJ, I agree with the idea of tapping a slightly oversize allen wrench into the hole and then backing the bolt out. If you can only get it out a bit then you may have enough area to grab with a small pair of vise grips to finish the job (and the bolt).
Since you are replacing the bolts with new OEM, go one step further and heli-coil each of the holes. You won't have to worry about them after that. I'll be doing the heli-coil mod on my next oil change.
  • Kawabuggy
Posted April 21, 2007 - 06:51 AM
Those bolts on the filter cover should not be recessed. You should easily be able to grab the head of the bolt with a pair of pliers, and then work it out. Otherwise, try the over-size allen wrench idea. I just went through this recently.
One thing I was sure to do when putting the new screws back in was to use anti-seize on the threads for those 3 bolts, and DO NOT OVER-TIGHTEN them! There is an o-ring seal on the cover so you only need to snug the bolts. The anti-seize will insure that the next filter change they will come right out without stripping the bolts.
When I recently did my top end, I used anti-seize on EVERY bolt that went into threaded aluminum. Some will say I should not have used it, but I just feel more comfortable knowing I won't be pulling threads out with the bolt years from now when/if I have to go into the motor again.
