blowing globes on wr450 04 model please help
7 replies to this topic
  • paswr450
Posted April 19, 2007 - 08:44 PM
my wr450 seems to be blowing globes,i am suspecting the rectifier could be faulty,could someone please confirm this for me and let me know what is the correct voltage out of the rectifier. much appreciated
  • SXP
Posted April 20, 2007 - 06:07 AM
Does "globes" mean bulbs in Aussie speak?
  • PBDBLUE
Posted April 20, 2007 - 06:32 AM
Out of the manual:
13.0 ~ 14.0 VAC at 5,000 r/min
  • bigdanner
Posted April 20, 2007 - 07:49 AM
I have heard of those regs going bad on the AC output. If you test voltage at the headlight you should around 13vac, but not much higher when you rev the motor. If you do you will need to replace the voltage regulator.
  • thumbthrottler
Posted April 20, 2007 - 08:27 AM
I had similar problems with my 05 from the start. Turned out the regulator/rec and stator were all in cahoots, and had to be replaced.
I called Trailtech, and ended up replacing the AC/DC system with a YZ or yzf stator and their regulator.
After looking into the AC/DC logic on the WR, I don't really understand why they do it that way, instead of staying with the YZ setup.
  • LeadDoggy
Posted April 20, 2007 - 08:41 AM
voltage regulator would be my guess
  • paswr450
Posted April 22, 2007 - 04:23 AM
thanks again,just confirmed the voltage out of the front light,actually reading 28 volts ac .suspected that it may be a bad grounding,rectifier definatley fried,its going to cost me 140 bucks australian to get one .just blew 300 on new michellin m12s ,does any body rate these tyres
  • moose offroad
Posted April 22, 2007 - 04:31 AM
The only tires we use.......:applause:
