426 cam mod??!
5 replies to this topic
  • klx300rider
Posted April 19, 2007 - 12:51 PM
will these work for the 426 cam mod? http://cgi.ebay.com/...104579478QQrdZ1
  • King_Air
Posted April 19, 2007 - 02:35 PM
I can't determine from that ad. I don't see the year listed. It needs to be a 03 cam. Later years may work but I don't know the cut off as you go higher in years. New is only like $103 from the TT OEM store. I would be leary of buying used cams based on a photo IMO.
Posted April 19, 2007 - 03:22 PM
The exhaust cam from any YZ450 regardless of year will work, but the '03-'05 cam is the one most everyone has so far used.
  • jbrooks26
Posted April 19, 2007 - 04:19 PM
I could be wrong, but I believe the YFZ cams are closer to the WR cam than the YZF cam. However, if those are actually out of a Yamaha then they are auto decomp cams and will work in your head if timed properly. Now all you have to do is decide if you are comfortable buying these parts used off of Ebay. Hope this helps.
Josh
Posted April 19, 2007 - 07:24 PM
Damn it. I hate that the quad cams are YFZ and the bikes are YZ*F. I'm always getting tripped up by that. The correct answer is yes, they'll go in the engine, but no, they aren't what you want. It would be a big step down in power. :thumbsup:
  • King_Air
Posted April 20, 2007 - 03:32 AM
Damn it. I hate that the quad cams are YFZ and the bikes are YZ*F. I'm always getting tripped up by that. The correct answer is yes, they'll go in the engine, but no, they aren't what you want. It would be a big step down in power. :worthy:
I got tripped up by that also. Gray tell the boys @ Yamaha to change the YFZ designation to something else :thumbsup: lol.
