YZ450F Leaking collant from Watter Pump Weap hole
2 replies to this topic
  • msoracing
Posted April 15, 2007 - 06:42 PM
My 2004 is leaking coolant from the Watter Pump weap hole.
Could someone explain what I need to replace to repair this?
Thank you
Posted April 15, 2007 - 06:51 PM
Replace the two seals on the water pump impeller shaft, and the shaft too, if it has a groove worn into it by the seal(s).
  • thumper450yzf
Posted April 15, 2007 - 07:21 PM
mine is doing the same thing, but yea just replace the seals and it should be fine.. speaking of that i need to go do that on mine.
