4 replies to this topic
  • dp400
Posted January 30, 2002 - 03:55 PM
Bike - 2000 WR 400 - stock except for air box snorkle removed and baffle removed. The bike runs good but has a flat spot off idle and will even stall if the throttle is chopped really hard. What do you guys think we should start with - adjusting fuel screw - if so, how many turns out? Or is the P-38 the answer. Any other ideas?? NEED HELP - thanks DAN
  • MN_Kevin
Posted January 30, 2002 - 05:31 PM
P38 is NOT the answer.
Correct jetting is.
You should disconnect your air cut valve, then proceed to tweak on your pilot (fuel) screw.
  • dp400
Posted January 30, 2002 - 07:21 PM
Whats a AIR CUT VALVE? Where is it and how do I disconnect it? Is the stock jetting the way to go? If not what? Thanks Dan
  • dp400
Posted January 31, 2002 - 06:01 AM
Is anyone there - Keven - ANYBODY !!!
  • dp400
Posted January 31, 2002 - 06:15 PM
