yz426 suspension bottoming out?
6 replies to this topic
  • klx300rider
Posted April 13, 2007 - 09:02 PM
I have an 02 426 and it seems like the landing is way too hard, even off medium sized jumps. I only weight 150! Any advice?
  • Ga426owner
Posted April 14, 2007 - 01:50 PM
loosen or lessin your compression dampning....a lot .........first, if no good
service forks and shock with new fluids and possible less rate springs for your weight...it is stiff probably and not bottoming....:thumbsup:
  • 642MX
Posted April 14, 2007 - 01:53 PM
Send it off for a revalve and springs. Its amazing what a good suspension tuner can do for the 426.
  • buzzgrizz
Posted April 14, 2007 - 02:24 PM
It is probabaly way too stiff, loosen it up.
  • klx300rider
Posted April 15, 2007 - 08:16 PM
Sorry for the misunderstanding...I meant the suspension is too soft, causing the hard landing!
  • TL426
Posted April 16, 2007 - 06:13 AM
about how much does that cost? im thinking mine needs to be done also...
  • 642MX
Posted April 16, 2007 - 07:02 AM
This guy did mine. http://www.smartsuspension.com I forgot the total cost, I had him revalve the front and rear with new seals and everything. I already had the correct springs, so I didn't have to buy those. Give him a call, I'm sure he can tell you what it will cost.
