stator mod done, how many ac volts?
2 replies to this topic
  • ZEHR
Posted April 13, 2007 - 06:07 PM
I've done the stator mod that BD explains on thier web site, I would like to know if anyone has checked the AC voltage they get from the Yellow to the White wire BEFORE it goes into the reg/rec. My reading is a 28-31 volts AC is this normal, please help. I've checked all over the forum and can't find a good answer, thanks again!!
I have a 04 WR 450f sm thanks!
  • mikey m
Posted May 06, 2007 - 04:00 PM
iwas told by bd my 01 426 should be 30- 50 vac at high rpm .at lest you have voltage mine dont
  • Gadsen
Posted May 06, 2007 - 06:43 PM
That is probably "open circuit voltage" and it will be higher. The lighting coil cant take a heavy load and when the light is installed, it "pulls" the AC votage down to a reasonable level and is why it didnt need regulating. But if you are upping the system power (amps), it needs to be regulated or the light will burn out quickly.
