How can you make an 06 450f more snappier?
17 replies to this topic
  • CaptainKnobby
Posted April 12, 2007 - 04:53 PM
I was wondering on my 06 450f what could I do to make it more snappy! I have a DRD full exaust on it but I want it to be more quiker on take off when your at a dead start. I also would like it to accelerate more quiker when you slow down for a turn and then wring it. Is there anything I could do to make it zip!:thumbsup: ...... I want it to be like> when you twist the throttle real fast....... if you aint holding on it will come out from under you.:worthy:
  • YFZ450_725
Posted April 12, 2007 - 04:55 PM
go up 1 or 2 teeth on the rear sprocket.
...or trade it in for a CR 500
  • Ranger18
Posted April 12, 2007 - 05:03 PM
I know this isn't english class, but dude... more quicker
Two more teeth on the rear sprocket
hot cams stage 1
ap mod or zipty carb mod
a little more sag might allow the rear tire to hook up better.
lower air pressure will have the same effect.
make sure your air fuel screw is adjusted properly.
I only have an MRD system and proper jetting, and my bike wants to throw me.
  • ThompsonV311
Posted April 12, 2007 - 05:04 PM
Four words..... Zip Ty carb mod!
  • black_n_blue_thumper
Posted April 12, 2007 - 05:35 PM
Please dont forget "more snappier":busted:
  • 133_Bradley
Posted April 12, 2007 - 05:40 PM
Sell off that '06 and buy an '04 with a 13.5:1 JE piston and a yoshi exhaust and you'll be buying some new underware
  • CaptainKnobby
Posted April 12, 2007 - 07:41 PM
I like that one^^^^^^^^!
  • CaptainKnobby
Posted April 12, 2007 - 07:45 PM
hot cams stage 1
I have a 51 rear sprocket on and that did help some but I was wondering ranger 18 if you have done the red beard ap wiring mod?
  • MXer241
Posted April 13, 2007 - 04:20 AM
I'd say carb mod but it does not have to be zip ty. You can get a white bro kit for about 100.00. I have one and it makes for a crisper throttle and no popping.
  • Ga426owner
Posted April 13, 2007 - 04:58 AM
The Zipty did this exactly....quicker off launch as well as corner entrance/exit....nice 1.5hp increase that you can feel:thumbsup:
  • Ranger18
Posted April 13, 2007 - 06:46 AM
No I haven't. I was thinking about doing the AP mod, then after hearing about the zipty mod I was thinking about doing that, but then I realized that I didn't need either mod. My bike has great throttle response, and zero bog, with just the slightest of popping on decel. Basically I think my bike is perfect, although when I get a new chain and sprocket kit I might go with the 50 tooth rather than the 49. Also, don't get me wrong, I would still like to do the zipty mod eventually, but it's more for the power(that I don't need) and just to say that I have it.
If you have no popping at all, then you are a littel too rich, and you should turn your fuel screw in a little. This will improve the bikes performance. Any performance carb tunner will tell you that the power is made on the leaner side of pefect jetting.
  • Yamahafan
Posted April 13, 2007 - 08:28 AM
If you have no popping at all, then you are a little too rich, and you should turn your fuel screw in a little. This will improve the bikes performance. Any performance carb tunner will tell you that the power is made on the leaner side of perfect jetting.
Ditto.
  • kawirider
Posted April 13, 2007 - 10:24 AM
Get this 502 big bore and stroker kit
http://www.faliconcr...com/stroker.htm
if thats not enough you will never be satisfied.
  • moto867
Posted April 13, 2007 - 04:05 PM
I have done the red beard ap mod on my kawi 450 and it works awesome. I was skeptical, but i tried it and it works. You have to go way up on your leak jet but its no big deal. I have an 80 in there now, thinking of trying a 90 just to see. I am not sure what the yami has in it stock but you will want to go up a bunch. It's free and worth a try. If you don't like it you just un wire it and buy a new diaphragm and your back.
  • buzzgrizz
Posted April 13, 2007 - 04:37 PM
Put a Boyesen quick shot on it.
  • CaptainKnobby
Posted April 13, 2007 - 08:44 PM
How can i get in touch with zipty to get them to do my carb?
  • cowboyona426
Posted April 13, 2007 - 08:57 PM
Zip-Ty carb mod
  • MXer241
Posted April 16, 2007 - 01:09 PM
My bad, I shouldn't have said no popping. Reduced popping would be a better description.
