Is the HRC Needle seat different from stock?
5 replies to this topic
  • drop
Posted April 12, 2007 - 03:34 PM
I see Baja Designs offers the B53E needle (part 151009) but it doesn't come with a needle seat. Is the stock seat the same part?
  • Billahjack
Posted April 12, 2007 - 05:05 PM
You should get a needle, an E-clip, and a needle jet when you order this kit. It was $35 at my local Honda shop. You need the Needle Jet with the correct Needle if you swap them out.
  • HawkGT
Posted April 12, 2007 - 06:29 PM
I looked into the needle jets before and came to the conclusion that they are identical for both the B53E and B53D jet needles. I came short of actually mic'ing the two needle jets but was satisfied that they are the same.
But as Billahjack said, the jet needle should come with a new needle jet. At least when you buy it straight from Honda it comes with one.
  • Billahjack
Posted April 12, 2007 - 06:37 PM
The tapers are supposed to be a little different on the needles for a different fuel mixture relative to throttle position (fuel curve?). I have not measured the jets either, but the Honda dealer told me not to mix them up.
  • HawkGT
Posted April 12, 2007 - 06:54 PM
Just so I'm not making things confusing by using the terms "needle jet" and "jet needle"....(hell, that nearly confuses me and I'm typing it, lol).... :thumbsup:
Yes, the needles themselves are different. However, I do not think the jet the needle slides into is different. When you order a new needle (be it stock or the HRC) the jet needle comes with a new needle jet (damn terms with their nearly identicalness!) but I believe the needle jet (needle seat) is the same piece.
The reason I wanted to know about that was because I wanted to know if I needed to switch the needle jet everytime I switched the needle. I decided I did not need to do that.
  • jbird710
Posted April 12, 2007 - 06:55 PM
Also, the seat doesn't have to be pressed out like some carbs. Once you remove the jet holder, the seat will fall out - it's simple to replace.
  • Hot  60 replies
Would a Young Scott Summers still be Competitive today on an XR600R? What would he ride to be competitive today? by Jayzonk
  • Hot  159 replies
  • Hot  29 replies
  • 22 replies
  • 9 replies
