Easy way to adjust rear shock??
Is there an easier way to adjust the rear shock? The manual says remove the rear frame. There gotta be an easier way. I need to add a little more sag.
Ron
'02 WR426 -- 1.5 hours on it so far ?
Soon to be street legal
It only takes about 5 minutes to remove the subframe assembly and it does make it way easier to adjust. The only downside is that you need to reinstall the subframe to check the sag. Don't forget to take off the bolt that holds the rear brake reservoir.
One other question to this. The guy at the shop said the rear shock should loosen up a little once the bike gets broke in. Since I have only about 1.5 hours on the bike is it ok to give it more sag now? Just seems to stiff for me right now. Maybe I need to gain a little weight. ?
[ January 30, 2002: Message edited by: RonO ]
