Those small peep holes on side of motor?
9 replies to this topic
  • CaptainKnobby
Posted April 10, 2007 - 05:41 PM
I was wondering on my 06 450f yz.... What are those small round peep hples on the side of the motor(the kick stsrter side). Should I cover them up when I wash the bike?:thumbsup:
  • gt2894me
Posted April 10, 2007 - 05:49 PM
That is a drain hole for the spark plug well. You should have a rubber plug on a wire that came with your bike if you bought it new. Put that in only when you wash your bike.
Happy cleaning!
  • Dizman
Posted April 10, 2007 - 06:18 PM
Another use for that hole - after removing the spark plug cap and before removing the plug, blow compressed air into the hole to blow out any dirt that may be in there.
Posted April 10, 2007 - 06:20 PM
:ride: The rod with the hook on one end, and the rubber on the other? That's for lifting out the jet needle. :p :ride: Very creative use for it, though. :worthy: :thumbsup:
Use a golf tee and leave the tools in the tool box.
  • CaptainKnobby
Posted April 10, 2007 - 06:35 PM
Happy cleaning!
Yea my bike came with that wire with a rubber end on it but I used it to get the jet needle out of my carb but I was wondering why does the sparkplug well need a drain hole?:thumbsup:
  • Markopolo400
Posted April 10, 2007 - 07:21 PM
Why do you guys plug up a purpose built drain?
Posted April 10, 2007 - 08:18 PM
..I was wondering why does the sparkplug well need a drain hole?:thumbsup:
Um, so fluids won't stand around the spark plug, short out the ignition, and run down into the cylinder when you pull the plug out, maybe?
The plug boot, effective as it may be, can let water in, and the cam cover gasket, as great a piece of work as it is, could leak oil into the well. If you don't provide a way for it to get out, you'll have trouble.
I rarely bother, myself. But some people like to plug it up when they wash the bike because they think they can drive a significant amount of water into the plug well while the only way for the air to get out of the way is sealed off at the other end. :worthy: There's no harm in it, though, is there?
  • Ga426owner
Posted April 11, 2007 - 01:40 PM
If you do not cover the hole with a golf tee before washing or do not blow compressed air into it with spark plug cap off - before removing plug after washing
the plug will rust/contaminate causing trash to fall into your cylinder when removing the spark plug.....a real mess. All it takes is a golf tee to fix this issue.
The drain is there to let debree fall out of it that may get under spark plug cap - with contact cleaner that is:thumbsup:
  • CaptainKnobby
Posted April 11, 2007 - 05:30 PM
Wouldnt it be better to take the sparkplug cap off and blow compressed air down to the sparkplug so the debri would either blow upward and even some may come out of the hole.
Posted April 11, 2007 - 05:32 PM
How much difference would it make?
  • Hot  36 replies
  • 0 reviews
  • Hot  33 replies
  • Hot  79 replies
