Help!!!!!!
20 replies to this topic
  • Lucien1964
Posted April 08, 2007 - 10:29 AM
OK guys I'm in a bind. My cycle went out on me in a remote location thus I had to hide the bike until I get parts to repair it. My buddies think the carb is jacked, no fuel getting to the engine. The bike is a Yamaha 2002 YZ426. I need to buy a rebult carb for my bike. Any links would be a great help thank you!!!!!
  • CRF59jk
Posted April 08, 2007 - 10:41 AM
Wait...?
Your bike is just sitting out in the middle of now where? And your gonna go out there and fix it when you get the parts?
  • Lucien1964
Posted April 08, 2007 - 10:48 AM
Wait...?
Yeah. The bike is in a canyon there is no ther way to get the bike out. My buddies will get me close and I will have to hike but I think we can get it running good enough to get it back to the truck. The problem was we ran out of sunlight and did not have the tools we needed thus I had to hide the bike. We have gps cordinates to locate the bike again I just need to get parts asap.
  • enduro4231
Posted April 08, 2007 - 10:49 AM
I would have pushed the bike before I even though of leaving it behind. Don't expect to see it there when you return.
  • CRF59jk
Posted April 08, 2007 - 10:52 AM
Hey jsust do this, put the bike in neutral and tie like a rop around it and then around your buddys bike and have them pull you out.
  • Lucien1964
Posted April 08, 2007 - 10:53 AM
We tried with 4 guys. We have to get it running. Trust me if its gets found and taken then they deserve the bike. Its in an extreme remote location hidden in deep bramble bush.
  • Lucien1964
Posted April 08, 2007 - 11:02 AM
Geez you morons are a big help to this guy...
Dude,,, no fuel ? ,, did you check the float bowel,,,, all the obvious stuf ?? as in the petcock filter in the the tank,, etc... ?
Walk it backwards from the tank, to the float bowel to a clog main jet etc... bring tools and a compressed air tank, filled to the max with a nozzle to try to blow ne crap out of the carb.
good luck and im sorry you got so many dickheads giving you lectures,,
peace
Thank you I know tyhere are some great and not so great people in this forum. I figured i would be patient and wait for the right poster to reply. Thank you for the input. :thumbsup:
  • CRF59jk
Posted April 08, 2007 - 11:05 AM
Or you could get a helicopter and hook it on to a cable and fly it out.
lol, may work
  • Lucien1964
Posted April 08, 2007 - 01:05 PM
bump!!!!
  • mudhog426
Posted April 08, 2007 - 01:23 PM
Lucien.....any number of things could be causing your bike to have quit. We need a little more info to help armchair diagnose the problem. Did the bike quit suddenly? Did it seem to bog down before quitting? etc.
As for the less than helpful posts go, most folks would only leave their bike as an absolute last resort, then their first priority would be to retreive it and then fix it once recovered. Only you can make the determination if stashing it will be o.k.
  • Not-So-Fast
Posted April 08, 2007 - 01:25 PM
I separated my shoulder and had to leave a bike in the woods for a weekend. Don't worry too much about it. When is the last time you went off trail looking for a stranded bike? Neither has anyone else, and what are the chances THEY'LL have the carb parts to fix it. Good luck on the carb. As a last resort, in addition to taking in parts, you might see if your dealership will sell you a brand new unit and let you return it for a restocking fee if you don't end up using it. Given your situation, the cost of a new carb is surely less than an entire bike!
  • Not-So-Fast
By the way, what were the GPS coordinates? ... Just kidding.
  • SoCA_DRZ
Posted April 08, 2007 - 02:18 PM
ck all the obvious things:
Are you getting spark? Pull the plug and kick the bike over to see if there is an arc
Do you have compression? Is it as hard to kick over now as it was before?
Are you getting gas?
Since you think you are not getting gas, just bring a can of carb cleaner and some compressed air if you can. Pull the carb and remove and clean the jets with the carb cleaner and then blow them out. Put it back together and give her a kick. You shouldn't need a rebuilt carb. 90% of the time, it will just be a clogged jet. While you have the fuel line disconnected from the carb, turn the petcock on to make sure gas is getting to the carb. BTW, when was the last time you adjusted the valves? Tight valves can make a bike difficult to start. If the bike is in So Cal and you can't get it running yourself, I know a guy that is a mechanic that will do it for you. It will cost you though. Good luck!
  • Lucien1964
Posted April 08, 2007 - 02:43 PM
We did not check for spark we will when we go out there. the compression is fine the bike bogged down then quit. The gas line is fine when we unhooked it gas was flowing from the tank normally. I will bring out a card ,spark plug and filter. Hopfully the electrical is ok if not I will have to make 2 trips. If you guys have links to good places for rebuilt cards that would be helpful. i appriciate all the good feed back you guya are providing. These are the best forums on the net in my opinion.
  • SoCA_DRZ
Posted April 08, 2007 - 04:52 PM
For carbs, try these guys:
http://www.sudco.com/
  • 1rkcooper
Posted April 08, 2007 - 08:44 PM
Seems a bit extreme to have to change the carb. Like SoCa DRZ said take out a can of carb cleaner and two or three of thos esmall cans of compressed air that you can buy, give the jets a good cleaning. Sounds more like a bad plug or clogged jet to me. Good luck.
  • Lucien1964
Posted April 16, 2007 - 02:57 PM
WOOOHOOO!!!! Got the bike back. Thank you for all the help and advice. :thumbsup: :worthy: :ride: :ride:
  • AndrewBrittain
Posted April 16, 2007 - 03:48 PM
Ok, I'm curious now..What was the problem?? I've had a similar experience and my bike quit about a half hour from camp in FL.. turns out it was a clogged jet. I had to walk it out.:thumbsup:
  • Lucien1964
Posted April 17, 2007 - 07:07 PM
Part clogged jet with a dose of vapor lock.
  • BergArabia
Posted April 19, 2007 - 07:19 AM
Good for you dude. Glad to hear you had a happy ending..
