HRC Exhaust tip or similar needed
4 replies to this topic
  • Zapp22
Posted April 05, 2007 - 11:57 AM
if any of you have or know where I can get used HRC exhaust tip or similar for XR650R ??? need
z
  • Xr650rhonda
Posted April 05, 2007 - 12:18 PM
[quote name='Zapp22']if any of you have or know where I can get used HRC exhaust tip or similar for XR650R ??? need
z[/QUOTE
If your looking for similar, why can't you core your stock tip?
  • Zapp22
Posted April 05, 2007 - 12:24 PM
[quote name='Xr650rhonda'][quote name='Zapp22']if any of you have or know where I can get used HRC exhaust tip or similar for XR650R ??? need
z[/QUOTE
If your looking for similar, why can't you core your stock tip?[/QUOTE]
perfectly reasonable question and gets to the real point: that's what I have now. the previous owner did it, or bought it, or had someone do it, and I'm very curious if I could get back a little of the high end by using the HRC part. Dimensionally, the opening of the HRC is a little smaller, and I'm not sure about the basket dimensions, but also the HRC is barely within the legal noise limit.... which mine probably is not....
all suggestions welcome!
  • Xr650rhonda
Posted April 05, 2007 - 12:44 PM
[quote name='Zapp22'][quote name='Xr650rhonda']
all suggestions welcome![/QUOTE]
The HRC tip may be smaller in opening, but runs deeper past the baffle inside the muffler and is much louder. My cored tip is around 94-96 db's and I know people post the HRC tip as 96db's, but I think it's closer to 98. I'm using a radio shack Db meter, so I'm close at best. I feel it does have more top end over the cored tip and the bike seems to really wake up with it, but it's loud.
  • Thumpage
Posted April 05, 2007 - 02:47 PM
Hey guys, Check this page link out on a recent thread. Start at post #53.
Just to be sure the stock tip 'coring' you are talking about is inline with this. Anything less is not nearly the same as a HRC tip.
http://www.thumperta...t=464838&page=6
If your has in fact been done very similar, then try going back to a HRC tip if you want or need more top end power.
We are currently in the process of sound testing the tip/s, so stay tuned for the results.
